Shed/Playhouse Door Handle? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 03:08 PM   #1
Rewards Points: 152
Shed/Playhouse door handle?
I am having trouble finding a handle that would be good for a playhouse. I need something that will be able to open from both the inside and outside.
Any ideas?
Thanks!
sandyman720 is offline   Reply With Quote
Old 03-26-2012, 04:31 PM   #2
look at these
http://www.homedepot.com/Tools-Hardw...searchNav=true
Hardway is offline   Reply With Quote
Old 03-26-2012, 04:51 PM   #3
Why not just use a standard closet handle
AirdrieHandyman is offline   Reply With Quote
Old 03-26-2012, 04:54 PM   #4
i am sure the op made the door. and not more then an inch thick.
Old 03-27-2012, 07:28 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
If the door is too thin, glue and screw a 6"x6" block to the inside and then drill it for a standard knobset.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
DangerMouse (03-27-2012)
Old 03-27-2012, 07:35 AM   #6
the Musigician
DangerMouse's Avatar
or.... use one from a screen/storm door since they are for thinner doors as well.
DM
Old 03-27-2012, 08:40 AM   #7
"If the door is too thin, glue and screw a 6"x6" block to the inside and then drill it for a standard knobset."
"or.... use one from a screen/storm door since they are for thinner doors as well."
Two good ideas, storm door handle would be the easier.
Duh I should have thought of the storm door handle, as it is what we used on ice shanty years ago.
Shed/Playhouse Dormer? sandyman720 Building & Construction 1 02-21-2012 12:18 PM
