Shed Permit? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 11:58 AM   #1
Shed permit?
do i need a permit to build a portiable shed? not grounded at all.
aharris01 is offline   Reply With Quote
Old 11-09-2012, 12:10 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the forum!
it would depend of the size, as well as the requirements of your local jurisdiction. check to see if your building department has a website. typically information such as this would be found there, if not give them a call.
hope this helps!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-09-2012, 12:11 PM   #3
Rewards Points: 6,652
Really depends on where you live, and if you have a Home Owners Association.
Old 11-09-2012, 12:14 PM   #4
Rewards Points: 3,130
I have lived where a shed under a certain size required no permit. I have also lived where a pre-manufactured dog house did require a permit and inspection. Just depends on the rules where YOU live.
Old 11-09-2012, 03:01 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As others have stated, each location (or state), will have a maximum SF size limitation, for when a permit is needed for a shed. See your local Building Dept.
Also, bare in mind that other statutes my come in to play, such as zoning laws (limiting locations and heights of sheds).
- Build Well -
Old 11-09-2012, 03:32 PM   #6
concretemasonry's Avatar
Rewards Points: 2,594
A shed is not a livable space, so the permit requirement may actually be a zoning or land use (depending on square footage), especially in areas with high winds.
I have seen 8x10 or 8x12 sheds (10' ceiling heights for maximum usable floor space) built without permits because the voiding of the permits worked well in areas with owners having tight schedules for inspections and that, but overbuilt for electrical and structural. When you have wall space for hanging things, it frees up the floor for important things like a refrigerator in the corner.
Dick
concretemasonry is offline   Reply With Quote
Should I/ Can I get a permit for a redone tub and surround after it was completed? amodoko Remodeling 9 11-10-2012 06:02 PM
A Permit After 19 Years? JulieMor General DIY Discussions 36 08-20-2012 08:45 AM
DIY Electrical. Permit, Inspection, Liability Concerns Stemboat Electrical 13 08-01-2010 04:21 PM
Basement ceiling height & Permit troubles mayo302 Building & Construction 5 06-04-2010 09:21 PM
No Permit for my Porch and Deck jokiddjr Building & Construction 15 06-13-2007 10:34 AM
