Shed - Metal Strap? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-02-2012, 09:58 AM   #1
Shed - metal strap?
http://www.buildeazy.com/greenhouse5-6.html
Here they talk about metal straps to support the rafters on one side (the other side uses blocking). The folks at Lowes don't know what I'm talking about and the only thing I could find was that strapping that comes in a roll. Surely that can't be it?
http://tinyurl.com/cn2dkhf
Cheers!
Octavius is offline   Reply With Quote
Old 05-02-2012, 10:04 AM   #2
Rewards Points: 2,212
the strap is there for diagonal bracing. Look up Lumber Yards or Hardware stores in the yellow pages. You want one that contractors use not a big box.
mae-ling is offline   Reply With Quote
Old 05-02-2012, 10:06 AM   #3
Rewards Points: 14,290
http://strongtie.com/products/connec...S-HST-LSTA.asp
If they had them they would be in the same area as the joist hangers.
Old 05-02-2012, 03:31 PM   #4
Joe,
Thanks for the tip - just got back from Lowes - the longest Simpson brace was 2'.
Mae,
Thanks for replying - there's one up the road - I'll see what they have.
What would be the proper name for this stuff? "Rigid metal strap bracing"?
Would blocking (with one set of 2x4 blocks) be a good substitute? I think the original design calls for bracing as it would let in more light.
Cheers!
Old 05-02-2012, 07:57 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
sounds like you are talking about hurricane ties, also called hurricane clips. a metal connector that attaches the rafter to the wall. is this what you are trying to describe?
http://www.strongtie.com/products/connectors/H.asp
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-02-2012, 08:54 PM   #6
dogris's Avatar
This may be what you are looking for - Diagonal Metal Bracing.
http://www.strongtie.com/products/co...C-TWB-RCWB.asp
Lengths ranging from 9'-6" through 14'-2"
dogris is offline   Reply With Quote
Old 05-02-2012, 10:28 PM   #7
Good link. 3 types I have seen. a long metal strap that comes in a roll. A T shape that gets put into a saw cut, and L shape that gets put in a saw cut.
Old 05-03-2012, 12:08 AM   #8
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
The strapping on the roll you found at Lowe's would be fine in my opinion.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 05-03-2012, 10:17 AM   #9
IN my experience the strapping with the holes is not what is accepted. At least where I have worked.
Old 05-03-2012, 01:41 PM   #10
Mae-ling,
OK, what if that strapping was continued over the roof and down the corner studs a foot or so and secured.
Each pair of rafters is joined with a plywood gusset and a short 2x4. At the top of this fabricated truss there is a 2x4 running the length of the roof. So it's not like the metal bracing is all that will stop the roof from collasping.
Thanks for the replies so far.
Cheers!
Old 05-03-2012, 07:48 PM   #11
The metal strap is for diagonal bracing, we used to notch a 1.4 in to do this, then there was plywood. With no plywood there is nothing to stop it from collapsing. Some green houses use 3' or 4' plywood on the bottom to do this. Although there is the diagonal 2x4 in your plan for this.
Your roof would benefit from some bracing. I'd find the kind in Dogris' link. I think the kind with the holes may be to weak and buckle easily.
Old 05-03-2012, 09:40 PM   #12
AndyGump's Avatar
Rewards Points: 688
Well it is just a 2x2 plastic covered green house after all, not a 'to code' out building.
Andy.
Drip edge for top side of Shed style roof with metal roof? organick Roofing/Siding 10 09-06-2011 08:43 PM
Sinking Shed willise Building & Construction 3 05-04-2011 11:34 AM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
water run off in shed kathy k Building & Construction 4 08-09-2009 03:29 PM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
