Shed Insulation
I believe you'd be best off w/ a moisture retarding system, as I don't think anywhere is Washington is zone 7 or 8, where real vapor barriers are encouraged. This can be accomplished w/ vapor retarding paint and a tight drywall system. The trend is to get away from real vapor barriers as much as possible. You absolutely should use AIR barriers in and out, but the vapor barrier inside will depend on your climate. I would consider some insulation other than fiberglass batts, too; rock wool, cellulose, or cotton. Keep researching and check w/ local city/county engineers. I am not an expert, but have read a LOT the last few years. One good place to read is greenbuildingadvisor.com; buildingscience.com (?) is another. And here, of course. GL. john
