Old 10-30-2009, 01:35 AM   #1
Default shed foundation
I am about to purchase a 8x10 plastic shed (Lifetime Brighton). I was planning on building a wooden foundation on concrete blocks. Is this adequate? The plans suggest that this is OK but that a concrete slab is "preferred".
Other questions
Do I need to remove topsoil from the entire 8x10 area and replace with crushed stone?
Is it better to use timbers on concrete blocks, or just build the floor itself on the concrete blocks?
Thanks!
jkirby65 is offline   Reply With Quote
Old 10-30-2009, 06:42 AM   #2
Other questions
Thanks!
A wood deck is OK, but concrete is preferred for the manufacturer and you. Concrete is much more durable and easier to walk on and store things on. I have about a twenty year old shed that the deck is beginning to rot, and I am loathing the thought of removing the contents, moving the shed and repairing it. As far as the stone under the deck, I think it depends on the lay of the land. If it has a natural slope, and drains well, then stone can't hurt, as it slows the water evaporation, keeping the underside of the deck drier. It will also discourage skunks, groundhogs, etc from making it home. But if the ground is flat, and wet, then digging a hole is just going to be a constant pool of water under your shed, providing near 100% humidity all the time. Even though you fill the hole with gravel, only a portion of the water is displaced.
CustomBuild is offline   Reply With Quote
More On This Topic
People enjoy cooking on barbecues, but often get frustrated with the lack of space to work with. Building a counter around your barbecue adds space to set food, dishes, drinks and other items you need. You can also incorporate useful additions like... Read More »
When undertaking a home improvement project, you need to know how much concrete you will need and what kind is best for your project. Determining the right amount and kind of concrete you need will save you money and trouble in the long run. Read on to... Read More »
Here’s some of the things that we’re going to be using today. Some of these things won’t be used only because instead of the blocks I’m going to demonstrate the straw bales being mounted to, you’re typically going to have an... Read More »
A wet basement can wreak havoc on a home, resulting in cracks, destroyed possessions and contribute to the growth of unhealthy mold. Follow these quick techniques to safeguard your house against water damage. Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be checking for cracks around the foundation. When winterizing my house, the first thing I like to do is take a look around the foundation and see if any cracks have formed. Now... Read More »
Foundation for 8x10 Vinyl Shed fireberd350 Building & Construction 15 10-26-2009 08:26 AM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 08:28 AM
Shed Foundation rocksteady Building & Construction 3 04-21-2009 12:09 PM
reinforcement in a shed foundation footer - yay or nay ? amakarevic Building & Construction 8 04-01-2009 02:16 PM
Foundation for a 12X14 Shed emaizar Building & Construction 1 04-01-2007 06:04 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
