Shed Footing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2008, 05:06 PM   #1
Rewards Points: 1,062
Question
shed footing
while house footings need to go down below the frost lines, i was wondering if the same is true for a small cinder bloc shed, cca. 120 sq ft ?
thanks,
- a -
Old 04-28-2008, 09:03 PM   #2
General Contractor
joasis's Avatar
Yes. The point is frost heave....do it right, or get to do it over after a year or two.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 04-28-2008, 09:16 PM   #3
Question
bummer. the real pain will be digging trenches wide enough to set framing three ft deep.
considering that trenches are molds in and of themselves (though far from precise, is it okay to do away without framing ?
Old 04-28-2008, 09:55 PM   #4
Registered User
Termite's Avatar
You can use the soil as a form for the footing as long as it is dimensionally consistent. Tench footings are very common!
Old 04-29-2008, 10:45 AM   #5
Rewards Points: 1,910
You might be able to do a floating slab for a shed in your area. Check with a local inspector. But I don't know how well block walls work on a floating slab so if you do that you might need to go with frame walls. Maybe someone else on here knows.
running uf to shed bobo60 Electrical 12 04-20-2008 01:41 PM
expanding existing concrete pad for shed lz300 Building & Construction 1 04-06-2008 08:20 PM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 02:22 PM
