Shed Floor Framing Out-of-square - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-11-2009, 08:57 PM   #1
bsfisher's Avatar
Shed Floor Framing out-of-square
My first shed project, I'm building a 12x12 shed and I have cut my rim joist 144" and each joist 141" (16"OC) when I measure corner to corner I'm off by about 5/8" do I try and push the longer corner-to-corner in about a 1/4"? if so HOW ??
or do I call it pretty good and just keep my plywood flooring square and not worry about 5/8" out of square?
It could be out because of a few crowned joist?
any help appreciated
-BSF
bsfisher is offline   Reply With Quote
Old 10-11-2009, 09:08 PM   #2
Old School
Willie T's Avatar
If you are off by 5/8", that means you only have to rack the floor by 5/16 to be square. That's doable with even a sledge hammer. (But protect the corner with scrap wood.) A "Come-Along" might make it easier.
Just check to be sure all your lengths are truly correct first.
Willie T
Old 10-11-2009, 09:27 PM   #3
bsfisher's Avatar
that's what I was thinking.....fasten one corner and just a couple clicks with a come-a-long (or sledge), check it until square and then fasten to my runners when square. Thanks
Old 10-12-2009, 12:30 AM   #4
Rewards Points: 1,016
A 2 lb sledge is one of my often go-to tools for situations like this.
Old 10-12-2009, 04:53 PM   #5
bsfisher's Avatar
got it PFC
I got it within 1/8" "PFC" pretty freakin close with the the old strap&ratchet and the BFH. It didn't take but one click to go from 1/8 to 3"
Thanks guys
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 07:28 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 10:05 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
roof venting via the soffit darren Roofing/Siding 8 04-13-2008 10:29 PM
