Shed Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2013, 11:44 AM   #1
Rewards Points: 396
shed door
I am building a playhouse for my son. It is 6 feet in height so obviously the standard door will not fit. Does anyone have any ideas what I can do for a door but that is weather tight as well? I have seen some ideas for using osb mounted to 2x4 bracing then on the outside is a piece 3'' and 1.5'' taller that fits in the opening but doesn't seem to be good as far as keeping water out.
detroittigerfan is offline   Reply With Quote
Old 08-01-2013, 11:49 AM   #2
Rewards Points: 674
Just by a cheap hollow core door from the big box stores (or free off of craigslist) and cut to size. Then take the core that you cut off of the end and reinsert into the hollow at the new end. You will have to remove the "door" pieces that are fastened to it so it will fit. Or else just cut a new piece of wood to fit. This will be at the very bottom where it will never be seen.
B
Beepster is offline   Reply With Quote
Old 08-01-2013, 11:58 AM   #3
Rewards Points: 396
B
how is that door going to be weather resistant?
Old 08-01-2013, 01:36 PM   #4
Rewards Points: 14,026
Why would you build it only 6' tall?
Going to take longer to build with all that extra cutting, going to waste 2' of lumber on every stud, making it hard to find a real door that's not going to cause issues later.
Once he grows up you pretty much have a short useless building.
Old 08-01-2013, 02:15 PM   #5
Rewards Points: 674
The same way your front door is weather resistant...prime and exterior paint.
B
Old 08-01-2013, 02:19 PM   #6
Rewards Points: 396
B
don't I need an exterior jamb?
Old 08-01-2013, 02:35 PM   #7
No way would I use a cheap hollow core door in a kids play house or outside.
I've replaced a ton of them that had delaminated and holes punched in them.
Old 08-01-2013, 02:39 PM   #8
Rewards Points: 396
Then what do you suggest for a door Joe?
Old 08-01-2013, 02:41 PM   #9
Go back and read my first post. Why 6' tall?
A regular pre hung steel door would be my first choice.
Old 08-01-2013, 03:34 PM   #10
Rewards Points: 396
Because that is the height.
Old 08-01-2013, 04:26 PM   #11
Rewards Points: 674
So where exactly are you in the process? I am answering as if you have a door opening to fill and Joe C is answering as if you are in the planning stage.
If you are in the planning stage, how $$$ is it going to be? I just seen a playhouse go up in our neighborhood complete with Pella windows. Haven't seen any kids playing in it yet though.
B
Old 08-02-2013, 07:19 AM   #12
I agree with those who counsel a ceiling height greater than 6'.
That being said, I needed a door for an existing cinder block bldg with a RO less than standard height. I went to a door company and they cut down a standard pre-framed exterior door for me.
Can't tell the difference if one didn't know beforehand.
RoyalAcresRod is offline   Reply With Quote
Old 08-02-2013, 07:55 AM   #13
Sorry for the misunderstanding. The O/P said "I am building a playhouse for my son"
not I've built a playhouse.
There's dozens of different ways you can build a shed door.
http://www.bing.com/images/search?q=...ures&FORM=IGRE
Just a whole lot more work to have to build one.
I like to see no battens on the outside. They tend to trap water and rot out or cause the siding to rot out.
Drip edge for shed door? garya505 Roofing/Siding 1 09-17-2012 04:10 PM
Security screen door dangerp Carpentry 4 09-22-2010 07:02 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
