Shed Building On Concrete Pillars - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2011, 03:20 PM   #1
Shed building on Concrete pillars
Hi
Building a 20x20 shed on nine separate 10" sono pillars.My question is this.The plans call for a particular Simpson connector that is only for a 4x4 post.Since i am using 6x6 post on top of the pillar how do i go about fasting the two 2x10 floor joists (running around the perimeter ) that will run at right angles to the outside corners to the 6x6 post?.
Thanks any help appreciated
rfcready is offline   Reply With Quote
Old 05-13-2011, 05:09 PM   #2
Civil Engineer
Rewards Points: 4,568
Simpson makes a bracket for connecting 4x beams to a 6x6 post. Call your designer and ask if you can use the correct bracket, I imagine they will be fine with that. I don't have my catalog with me, or I would quote the part number, but you can download the Simpson catalog off the Internet and get the correct part number from it.
Old 05-13-2011, 07:56 PM   #3
Thanks for answering but my problem is how to attach two sets of double 2x10 to the top of a 6x6 post at the corner pillars.
Old 05-13-2011, 08:15 PM   #4
Rewards Points: 558
Originally Posted by rfcready View Post
Hi
are you looking to do this?
epson is offline   Reply With Quote
Old 05-13-2011, 08:42 PM   #5
Thats at the bottom end of the 6x6 its the other end Im having problems with how to attach 2 sets of double 2x10 at the corners
Old 05-13-2011, 09:05 PM   #6
Rewards Points: 558
Well you can go to a metal fab shop and get a piece of 6’’ x 6’’ x 3/8’’ x 8’’ long angle have them punch ½’’ diameter holes equally spaced attach to your 2 x 10’s drill through and attach everything with ½’’ dia bolts with nuts and washers.
Old 05-14-2011, 09:08 AM   #7
Rewards Points: 1,442
Why not just screw the 2x10 rim joists to the sides of the short upright 6x6 pillar attached to the concrete pillar as shown above?
Drill pilot holes for the screws.
If for "double 2x10" you mean two rim joists, sistered, you can attach one joist to the post and attach the second joist to the first joist including multiple screws near the ends.
Example of double rim joist on pillar but with no 6x6 column. Note interlocking of ends of joists at corner permitting screwing into the ends of the joists. In your case I would use screws rather than nails to avoid hammer stress on the 6x6 column attached to the concrete pillar.
http://www.flickr.com/photos/1465531...57603785602889
Old 05-14-2011, 07:09 PM   #8
Thanks for the suggestion.what im going to do is notch the 6x6 so as the 2 2x10 will rest on top in either direction then plate then to get through inspection.
Old 05-14-2011, 09:36 PM   #9
Old School
Willie T's Avatar
Try looking at a Simpson Strong Tie BC46 4x6 Post Cap/Base
Franηois Duc de La Rochefoucauld
Willie T
Wood Shed Construction- Town wants concrete pad? TJ_in_IL Building & Construction 20 07-26-2011 10:21 PM
Building a deck on a concrete patio. Leon H. Building & Construction 9 03-29-2011 04:21 PM
Some more shed building questions. lukabrazi Building & Construction 10 02-05-2011 09:02 PM
Building a shed....approximate cost? secutanudu Building & Construction 8 08-05-2010 10:57 PM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 07:28 AM
