Old 10-31-2009, 02:40 PM   #1
Default Shed
I want to build a shed in my backyard. Kind of connecting to my deck that I am building at the same time. What kind of wood would you suggest that would make my shed durable and last. I am making my base from concrete.
AmericaM is offline   Reply With Quote
Old 10-31-2009, 03:07 PM   #2
Default Since you are connecting it to your deck
I recommend using cedar for both deck and shed if you want wood.
Another option would be to use some of the synthetic resin materials for the deck and a Hardie Plank type product (cement board) for the shed.
Most of the T-111 grooved plywood shed materials are very short lived. My T-111 shed is 25 years old but that is rare (impossible?) with today's materials.
MI-Roger is offline   Reply With Quote
Old 10-31-2009, 05:00 PM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
My shed is from reg wood, PT sill plate
It has T-111 siding that has lasted ages
I expended the shed & put cement board on the bottom 3' - due to the pool
I'm doing a stucco finish on the bottom
Wood will last as long as it is kept protected from the elements - just like any house
If the shed will be connected to the deck then they should match
And if it is near the house you might want it to match the house
I used just reg PT for my deck
The deck at my last house was over 20 years old when I moved
During the ~7 years I lived there I stained it the 1st year & the year the house went up for sale
Never did a thing to it in between
My deck here is over 2 years old & I will be sealing the wood next year
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 10-31-2009, 07:18 PM   #4
What do you mean kinda connecting to your deack? What you will find is that the longjevety of the wood is dependant on the situation that it is put into. What I meean is that wood will last a long time if it is sealed well and built in a way that will let it dry out when it gets we. However if you have something right next to the wood that won't let the air and sunlight to get to the wood to dry it out, you are lucky to get a few years out of it. Going back to my first question, how is the shed incorparated into your deck? Is the deck going to touch the shed? Is the shed on the deck? Is the deck butting up to the deck? The situation that you decide on will have an influence on how well the material will work.
RobQuillin is offline   Reply With Quote
Old 10-31-2009, 08:33 PM   #5
Well connected as in right next to it. I will try to post a picture of what i want when I get a chance.
Old 10-31-2009, 08:50 PM   #6
If the deck is going to be touching the deck you will want to make sure that you spend the time to get your flashing correct. That will make the biggest difference as to the longevety of the shed.
More On This Topic
Learn tips on how to write the word 'shed' with the Chinese Radical of wood in this free video clip on Chinese characters and foreign languages. Read More »
Finishing a deck can seem like an intimidating task with the different products and materials used. However, it doesn't have to be overwhelming when you break everything down into steps and figure out exactly what you need to get the job done. Read More »
A fresh coat of paint is a sure way to liven up your tool shed. Yet painting takes time. According to Matt Weber the trick to a good paint job is to plan ahead and be patient. Rushing the process will only lead to frustration and poor results. What... Read More »
Weather proofing a deck can save a homeowner thousands of dollars in repairs and deck replacements. Making a deck weather proof should be done as soon as the deck is built, or as soon as it comes into your possession. Keep it weather proofed to ensure... Read More »
Hi this is Drew Finn for expertvillage.com we are going to talk about cleaning and maintaining a deck. This video is presented by Black Dog Video and you can visit us on the web on blackdogvideo.biz. We have cleaned the deck, washed it down, we are... Read More »
water run off in shed kathy k Building & Construction 4 08-09-2009 05:29 PM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 08:28 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 01:09 PM
Shed Wiring bcdal Electrical 12 03-26-2008 06:51 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 11:56 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
