Sheathing Sofits/fascia With Aluminum - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 03:07 PM   #1
Rewards Points: 1,062
sheathing sofits/fascia with aluminum
hi. the rafters on my small shed overhang 10" on each side and i decided to enclose/wrap the overhang with some OSB first to protect the lumber from weathering and then wrap aluminum sheet around it. i already posted the OSB underneath (the rafter have L endings, so i nailed the horizontal 10" wide cut of OSB to the bottom of the L and will brace to the wall sheathing for firmness).
my question is: what kind of aluminum sheet metal should i get and in which kind of store should i look (i doubt big boxes carry it) ?
picture below
sheathing sofits/fascia with aluminum-sofit.jpg
Old 01-29-2011, 03:12 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
It's call coil stock
Some box stores carry it
All of your siding suppliers will carry it as well as most lumberyards.
I would put some kind of solid fascia on the rafter tails.
Don't rely on your coil stock to have enough strength across the bay openings.
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
amakarevic (01-29-2011)
Old 01-29-2011, 03:25 PM   #3
Smile
oh yes, i was definitely gonna put OSB on the rafter tails or maybe 1x4 if i decide i don't feel like cutting OSB lengthwise (i hate doing that). and then post the aluminum coil stock over that as well as the sofit under.
thanks again for all your help.
Old 01-29-2011, 04:28 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
yikes...i would pull off the osb you have installed at the soffit,do not use osb for the facia,install a 1or2x6 at the rafter ends
Use an F shaped soffit channel and use vinyl soffit
download and read this
http://www.vinylsiding.org/installat...nual/index.asp
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
tcleve4911 (02-02-2011)
Old 01-29-2011, 05:53 PM   #5
osb is ok for sheathing, where it is supported on all four sides. I'd NEVER use it for that purpose
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
Replacing Rotting Sheathing Behind Chimney. fredhead Building & Construction 4 11-19-2010 08:57 AM
Capping windows with aluminum VS flashing with aluminum scott j Remodeling 28 04-05-2010 11:19 AM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 12:12 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
