Sheathing At Intersecting Walls - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-11-2013, 02:33 PM   #16
Rewards Points: 77
What do you mean by blocked?
CheapCharlie is offline   Reply With Quote
Old 10-11-2013, 02:35 PM   #17
GBrackins's Avatar
Rewards Points: 2,108
2x blocking between studs. all panel edges must fall on 2x framing.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
CheapCharlie (10-11-2013)
Old 10-11-2013, 08:32 PM   #18
Rewards Points: 1,452
Maybe I'm misunderstanding the question. Can't the sheathing connect to the 2x4 at the top right of the pic?
mikegp is offline   Reply With Quote
Old 10-12-2013, 08:02 AM   #19
Rewards Points: 77
It can, but not if you sheet the walls before you stand them up. Then you'd have to add strips or do as I stated before. It's alot easier to square the walls up and sheet them when they're lying on the ground.
Old 10-14-2013, 04:32 PM   #20
firehawkmph's Avatar
Rewards Points: 1,864
Mike,
you could sheet your walls on the ground as Charlie suggested, and leave the plywood hang over 3 1/2" on each end. You would just have to stand it up on a slight angle in relation to the wall you want it to end up on, then slide one end over about 7", set the wall on top of your foundation, then slide it back to the other direction till everything lines up, if you follow what I'm saying. Or you could carry it around to the outside and set the bottom on your foundation and lift it straight into place that way.
Mike Hawkins
firehawkmph is offline   Reply With Quote
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 09:41 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
Insulating exterior walls with no vapor barrier or sheathing... rush General DIY Discussions 3 09-03-2010 07:58 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
