Sheathing Inspections? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2007, 09:02 PM   #1
Rewards Points: 152
I just asked my inspector if I can go ahead and put up my siding before I get any inspections. He told me that he needs to do a sheathing inspection.
He never told me that he needed to do this. All he said is that he needed a Plumbing, Elec, Framing, Insulation, Final inspections.
I have Tyvek on and the windows sealed.
What does he really need to see that he can't see from the inside?
sandyman720 is offline   Reply With Quote
Old 08-30-2007, 09:26 PM   #2
Framing Contractor
He needs to see the nailing pattern.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-31-2007, 07:48 AM   #3
Rewards Points: 152
Just talked to him. Now he said that it is not required but most builders want one. He said that all he needs to do is during the framing inspection, push one of the walls to make sure it is solid.
Old 08-31-2007, 12:27 PM   #4
Proper nails, nailing pattern, and sheathing material.
Did you do it to code for your area?
Inspector was very nice to you. GC's are usually responsible to get all required inspections even if they are not called out on the permit.
Local Building officials are not legally responsible for errors or omissions.
Big Bob is offline   Reply With Quote
Old 08-31-2007, 12:32 PM   #5
Rewards Points: 5,336
In NY the framing inspection was done with the sheathing in place. Besides nailing pattern and the size/type of nail used they also check the strapping that is now required.
Ron
Old 08-31-2007, 07:32 PM   #6
Extreme DIY'r Adk's, NY
Rewards Points: 272
crecore is offline   Reply With Quote
Roof sheathing overhang on fascia Clutchcargo Roofing/Siding 7 08-23-2007 01:02 AM
roof sheathing placement dmend Roofing/Siding 1 03-20-2006 09:03 PM
DIY Outbuilding 24' x 32' Sheathing Help Wanted LockDownLance Carpentry 6 10-09-2005 01:39 PM
Roof Sheathing Acceptable Tolerances? claypj Roofing/Siding 2 08-15-2005 03:16 PM
