Sheathing ID - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 05:41 PM   #1
Rewards Points: 150
Sheathing ID
These old images are all I have to identify this sheathing. The previous owner of the house put it up when he converted the carport to a garage (and now I'm converting it to office space). The rest of the house seems to have used a high quality asphalt coated blackboard.
As shown in the images, the inside of this sheathing is brown. I'm hoping someone recognizes this sheathing and can tell me what something about it and its intended use. Thanks.:
Inside:
Outside (both sides of garage door, image merged):
rightit is offline   Reply With Quote
Old 05-20-2012, 06:29 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
is the core like a wood fiber or like sheetrock?
Tom Struble is offline   Reply With Quote
Old 05-20-2012, 06:43 PM   #3
Rewards Points: 150
Hi Tom. It's fiberous. damaged spots (i.e., spots where a nail head tore through) were able to be picked apart.
Old 05-20-2012, 06:51 PM   #4
a few companies have and still produce it
maybe this can help
http://inspectapedia.com/structure/F..._Sheathing.htm
Old 05-20-2012, 07:14 PM   #5
Rewards Points: 150
Thanks for the link. It looks rather like Celotex, although I haven't seen any brand name on my limited samples.
Given that this is behind brick, my concern is that the exterior side of the board doesn't seem to be coated to make a good drainage plane, nor is any house wrap used. Fine when it was just a garage, with kraft faced FG and pegboard, but now that I'm creating air-conditioned office space, it's become a concern.
There's nothing I can do about it now, other than tear out the brick and replace the board and add wrap, but that's not going to happen, at least not for a while. I suppose the best I can do now is make sure that the weeping holes are clear and create more in the top of the wall for ventilation. Unless this sheathing repels moisture better than I credit it for?
Thanks for your comments.
Old 05-20-2012, 08:17 PM   #6
you should be fine
The Following User Says Thank You to Tom Struble For This Useful Post:
rightit (05-20-2012)
sheathing blocks instead of h-clips, help needed roof52 Roofing/Siding 25 04-12-2012 11:38 PM
is my sheathing rotting? *pics* Nospammer Roofing/Siding 24 03-07-2012 09:06 PM
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 06:56 AM
Replacing Rotting Sheathing Behind Chimney. fredhead Building & Construction 4 11-19-2010 08:57 AM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 12:12 PM
