Sheathing Height/placement On Wall Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-21-2009, 08:44 PM   #1
Rewards Points: 260
Sheathing height/placement on wall studs
The framing consists of a sole plate and double top plate with 92 5/8" studs. The sheathing/siding is normal 4x8 sheets. Is there a proper height I'm supposed to set it at. I was just going to follow the height of the old siding, but it is getting inspected. Therefore, I want to make sure I do it properly.
bluefitness is offline   Reply With Quote
Old 06-22-2009, 03:27 PM   #2
Rewards Points: 1,910
The optimum condition for blocking air infiltration is when you can use 9' sheathing all the way down over the rim joist.
If you go with 8' sheathing then place the bottom edge flush with the bottom of the lower wall plate. The top will overlap the seam between the double top plate by about 1/2".
Edit: If your sheathing is also the siding or your siding is then you do the same thing. The 4x8 panels will be 1" shorter than the stud wall height so you want that "shortage" to be above the soffit so it is not exposed.
Old 06-23-2009, 10:19 PM   #3
Registered User
Rewards Points: 4,910
The siding should be 6" above the ground, if concrete is over the ground, you may get by with less.
The bottom of siding should be 3/4"-1*1/4" below the sill plate. This gives a drip edge, and covers the gap at the sill/concrete. Caulk said gap before siding. Otherwise water will wick into the building at the gap.
If you install siding top even with top plates joint, it works very well. It gives you 1-1/8---1-1/4", down. Put a filler of waste siding at the gap above, before you install your soffit trim-1x4, over it.
Be safe, G
Gary in WA is online now   Reply With Quote
Old 05-12-2010, 01:42 PM   #4
Rewards Points: 508
With 8' panels what do you do to cover the rim joist? Would you cut a narrow strip of sheathing to cover that area?
benjamincall is offline   Reply With Quote
Old 05-12-2010, 02:27 PM   #5
kwikfishron's Avatar
Rewards Points: 86
If you have to go with 8’ panels you would then add Z metal on top of that and continue up with your next sheet. The problem is the next sheet won’t break on a plate or rim so would have to block the studs so you have continues perimeter nailing.
9’ sheets are really the way to go on the first floor then 8’ will work above that, assuming the building is only 2 story.
kwikfishron is online now   Reply With Quote
Old 05-12-2010, 04:25 PM   #6
Rewards Points: 508
I'm having a hard time conceptualizing the use of the Z channel between the sheathing panels. I was hoping I could avoid putting in the blocking.
I won't be putting sheathing on the above grade portion of the CMU walk-out basement, but I'll still have to cover up the rim joist.
I wish I had 9' panels, but my supply house had 8' Zip System panels.
Old 05-12-2010, 05:07 PM   #7
Rewards Points: 86
You need the Z metal flashing for two reasons, 1 it gives any water the may get behind the siding from above a place to escape and 2 it protects the top edge of the ply and the joint from the weather and delaminating. In fact you should hold the top sheet ¼” off the flashing so water can escape.
If you don’t block for nailing you’ll look up in a year (or less) and see a wavy mess.
Old 05-12-2010, 05:28 PM   #8
Rewards Points: 508
In my case, wouldn't the use of the Zip System tape and a rain screen eliminate the need for the Z flashing?
I was really hoping I could nail to the bottom of the top plate and just put a filler piece over the rim joist.
Old 05-12-2010, 07:42 PM   #9
Rewards Points: 86
I can honestly say, I know nothing about the “Zip Tape System”.
I just know what works for me.
Old 05-12-2010, 08:08 PM   #10
Rewards Points: 508
The Zip System is a coated sheathing that eliminates the need for a separate WRB. You tape the seams with a proprietary tape. Since I'm a slow-paced DIY guy, I appreciate not having to worry about tearing up Tyvek or having it whip around in the wind.
http://www.zipsystem.com/
Old 05-12-2010, 08:58 PM   #11
Registered User
It is still osb and a water resistive barrier similar to a house wrap. I would rather spend money on real plywood and real felt paper (30#). Think twice creating a water resistive barrier using taped seams....... especially with osb underneath: http://www.coastalcontractor.net/cgi...ticle.pl?id=14 http://docs.google.com/viewer?a=v&q=...GKM_FjuKp8QM-g
http://bct.nrc.umass.edu/index.php/p...d-and-plywood/
Be safe, Gary
Old 05-12-2010, 09:18 PM   #12
Rewards Points: 86
I have to say I’m always skeptical of “new systems” they have failed us in the past but what I just read on yours, the sales pitch sounds great.
Ask me again in ten years.
I’m “assuming” your sheet siding is T-111 a plywood product. The Zip system new sheathing with tape and no need for felt still doesn’t still doesn’t mean the plywood siding doesn’t need full perimeter nailing or protection on the exposed ends.
If you want to add a strip to cover the rim so you don’t have to block that’s up to you. It’s just that full sheets IMO look better.
Old 05-13-2010, 07:22 AM   #13
Rewards Points: 508
This product from Huber has been around for only three years, but I was a sucker for the wind-driven rain tests. The preliminary feedback I've read from contractors who have been using the product over the past several years is all positive. I probably won't find out if I've made a bad choice, since we're moving within the next ten years.
I guess I should have clarified that I'm using either fiber cement lap siding and fiber cement shingles over a rainscreen. The strip to cover the rim joist would be sheathing, not siding.
Old 05-13-2010, 07:56 AM   #14
Rewards Points: 86
Thanks for the clarification. Yes you can cover the rim with a strip.
I’d be trying to get it all covered up as soon as you can.
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
