#1 |
Lost..
Sheathing H-clips - When to use?
I had figured in to use h-clips for my sheathing on the roof of a project I am working on. I'm not sure where these actually need to be used in a roof deck. I will have my rafters on 2' centers and I'll be using 5/8 OSB for decking. From what I understand they are only used under unsupported edges but I may be wrong..
I don't see having unsupported edges though if everything will end up on a rafter. There should be no free hanging edges. Can anybody clarify this for me? |
#2 |
Clips are designed to be placed in between two rafters to minimize the span, in other words they are meant to almost serve as an additional rafter.There should be no need for clips with 19/32 OSB @ 24 O.C for standard roof application unless you are working on a flat roof.
See attached span rating table |
#3 |
most dont require on 5/8 with 2' span but I always used as its cheap insurance to eliminate warpage in the open span
The older I get the better I was |
#4 |
Agree, it is a good idea to use clips with CDX plywood , no need to be used with OSB in my opinion being that veneers are alternated and virtually there is no warpage.
#5 |
With 5/8 you dont need H clips. What is th slope? With a low slope deck you can use T&G below a torch on membrane. If it is a 4-12 slope or greater pass on the 5/8 and go 1/2" with H clips to save some money and 1/2 a log from the veneer mill.
#6 |
I hope I'm not stepping on anybodys steel toes but the H-clip does not alter the span it ties the two sheets together mid span and helps to distribute the load. |
#7 | |
Sheathing H-clips - When to use?Quote:
, i was just trying to simplify for the OP so he can picture the placement , you are right clips do not alter the span ( i meant to say minimize the span of the sheathing not the structure). |
#8 |
Lost..
The roof is a 6/12. The only reason I am using 5/8 decking is because I don't want sagging in between the rafters since they are on 2' centers.
#9 |
Moderator
It appears you are in Alabama. No snow loads? I'd use anything to help OSB in case it ever gets wet.
![]() http://www.strongtie.com/products/co.../PSCL-PSCA.asp Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! Last edited by Gary in WA; 01-24-2011 at 04:46 PM. Reason: forgot the link |
#10 |
Lost..
It is rare we ever see snow, and it usually isn't enough to amount to anything.
Anyway, for the price they would be cheap insurance against warpage, so I guess I'll use them. |
#11 |
Moderator
They do give you the required 1/8" gap on the edges, just remember to gap the ends breaking on the rafters as well; http://osbguide.tecotested.com/pdfs/en/el812.pdf
Gary
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#12 |
Lost..
Thanks. I was aware that there needed to be a gap, but didn't even think about the h-clips providing that gap. I'll just go ahead and use them.
#13 |
J S I'm in Canada with lots of snow and never used more than 1/2" with H-clips on a two foot span. Low slope roofs with torch on or tar and gravel I've gone heaver, up to 3/4 T&G
| Display Modes | |
| Replacing Rotting Sheathing Behind Chimney. | fredhead | Building & Construction | 4 | 11-19-2010 09:57 AM |
| House without exterior sheathing? | magnusrw | Building & Construction | 2 | 06-06-2010 03:13 PM |
| New roof and Sheathing - Install new fascia before or after? | hartkem | Roofing/Siding | 2 | 06-01-2009 01:12 PM |
| Moisture on Inside of Sheathing | elburritoloco | Building & Construction | 18 | 01-19-2009 09:16 PM |
| Hurricane clips... is this ok? | TravisT | Building & Construction | 5 | 12-24-2007 05:41 PM |
