-   -   Sheathing H-clips - When to use? (http://www.diychatroom.com/f19/sheathing-h-clips-when-use-93322/)
J S Machine 01-24-2011 10:24 AM
I had figured in to use h-clips for my sheathing on the roof of a project I am working on. I'm not sure where these actually need to be used in a roof deck. I will have my rafters on 2' centers and I'll be using 5/8 OSB for decking. From what I understand they are only used under unsupported edges but I may be wrong..
I don't see having unsupported edges though if everything will end up on a rafter. There should be no free hanging edges.
Can anybody clarify this for me?
SteelToes 01-24-2011 10:43 AM
plywood clips
Clips are designed to be placed in between two rafters to minimize the span, in other words they are meant to almost serve as an additional rafter.There should be no need for clips with 19/32 OSB @ 24 O.C for standard roof application unless you are working on a flat roof.
See attached span rating table
tpolk 01-24-2011 10:47 AM
most dont require on 5/8 with 2' span but I always used as its cheap insurance to eliminate warpage in the open span
SteelToes 01-24-2011 10:50 AM
Agree, it is a good idea to use clips with CDX plywood , no need to be used with OSB in my opinion being that veneers are alternated and virtually there is no warpage.
masterofall 01-24-2011 11:29 AM
With 5/8 you dont need H clips. What is th slope? With a low slope deck you can use T&G below a torch on membrane. If it is a 4-12 slope or greater pass on the 5/8 and go 1/2" with H clips to save some money and 1/2 a log from the veneer mill.
masterofall 01-24-2011 11:36 AM
I hope I'm not stepping on anybodys steel toes but the H-clip does not alter the span it ties the two sheets together mid span and helps to distribute the load.
SteelToes 01-24-2011 11:42 AM
Hey no you are not stepping on my toes :) , i was just trying to simplify for the OP so he can picture the placement , you are right clips do not alter the span ( i meant to say minimize the span of the sheathing not the structure).
:thumbsup:
J S Machine 01-24-2011 01:23 PM
The roof is a 6/12. The only reason I am using 5/8 decking is because I don't want sagging in between the rafters since they are on 2' centers.
Gary in WA 01-24-2011 03:35 PM
It appears you are in Alabama. No snow loads? I'd use anything to help OSB in case it ever gets wet.
http://www.strongtie.com/graphics/pr.../188b-2011.gif
http://www.strongtie.com/products/co.../PSCL-PSCA.asp
Gary
J S Machine 01-24-2011 03:47 PM
It is rare we ever see snow, and it usually isn't enough to amount to anything.
Anyway, for the price they would be cheap insurance against warpage, so I guess I'll use them.
Gary in WA 01-24-2011 03:52 PM
They do give you the required 1/8" gap on the edges, just remember to gap the ends breaking on the rafters as well; http://osbguide.tecotested.com/pdfs/en/el812.pdf
Gary
J S Machine 01-24-2011 03:53 PM
Thanks. I was aware that there needed to be a gap, but didn't even think about the h-clips providing that gap. I'll just go ahead and use them.
masterofall 01-24-2011 08:08 PM
J S I'm in Canada with lots of snow and never used more than 1/2" with H-clips on a two foot span. Low slope roofs with torch on or tar and gravel I've gone heaver, up to 3/4 T&G
