Sheathing Gap In Attic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2013, 02:46 PM   #1
just a dude
Rewards Points: 34
Sheathing gap in attic
Hi everyone,
I'm currently having an addition built. By the time I get home from work, the contractor is long gone and it's dark out, so I just look around on the weekend. If I have a concern, I'll give the builder a call.
Should I give him a call about this gap between the sheathing and the roof? It's like this on both sides where the roof peaks. Is this standard practice? If I'm going to ask him about it, I'd like to know the opinions of others in the business. I'm always friendly and professional when if I do have a concern, of course.
Let me know what you think. Thanks.
rocklobster is offline   Reply With Quote
Old 01-12-2013, 02:49 PM   #2
Rewards Points: 252
Poor workmanship, but will probably be covered by the soffit.
shazapple is offline   Reply With Quote
Old 01-12-2013, 03:05 PM   #3
Registered User
Rewards Points: 5,520
Call your local AHJ and ask them. If in a high-wind area that may not pass inspection. I'd make sure to read/understand the truss papers they should leave with you, for the correct required bracing, per engineer, eg. http://www.sbcindustry.com/images/pu..._images/b3.pdf
Gary
Old 01-12-2013, 04:17 PM   #4
Rewards Points: 13,750
Not the kind of work your paying them for, if it was me I'd make them replace it.
Old 01-12-2013, 05:28 PM   #5
just a dude
Rewards Points: 34
Looks like I'll be talking to him about it. Thanks for helping me keep an eye on things.
Rob
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 11:50 AM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Attic Insulation tim1218 Insulation 4 09-07-2011 10:18 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
