Sheathing Cutouts -- Best Tool For The Job? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-11-2009, 12:55 PM   #1
Rewards Points: 43
sheathing cutouts -- best tool for the job?
I am building a backyard shed. There will be a few windows, and I am building doors from the siding cutout pieces also. I am using 4x8 sheets of LP smartside (3/8" similar to osb sheathing).
I need to cut out the windows and doors which will be framed by 2x4's. What's the best way to do this? I have a circular saw and sabre saw but I think with those it will be hard to trim right along the framing.
Searching around I've seen people suggest using a router and a flush trim bit. This would make it easy to follow the framing, but am I asking too much of my (cheap) router to cut a bunch of 3/8" siding?
Thanks for any advice!
-R
flamtap is offline   Reply With Quote
Old 05-11-2009, 01:58 PM   #2
HandyMan Engineer
SkilSaw
I've always used a skill saw. My dad showed me this trick: Layout you window on the inside drill a hole in each corner and then use a chalk line on the outside and work away with the skill saw. You could use a sawzall but I find that wearks havoc on your fastners.
Hopefully you can still get inside with no windows or doors.
sendres is offline   Reply With Quote
Old 05-11-2009, 02:11 PM   #3
Rewards Points: 43
Ha ha. I have thought about that, and I'm hoping to avoid it!
Old 05-11-2009, 03:32 PM   #4
Registered User
Termite's Avatar
Drill the corners of the opening with a small drill bit from the inside and then just connect the dots on the outside. Your circular saw will work fine, just set the depth to 1/2" or so and use a chisel on the corners.
A router would work but that isn't how it is done by framers. The circular saw works just fine.
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 06:02 PM
Moisture on Inside of Sheathing elburritoloco Building & Construction 18 01-19-2009 08:16 PM
the tool for mounting real short nipples amakarevic Plumbing 2 11-01-2008 12:34 AM
