Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-14-2013, 12:11 PM   #1
Rewards Points: 396
Sheathing
When install sheathing is it normal to seal the 1/8" gap between panels with a caulk, sealant or spray foam or should you leave that gap unsealed so it can expand and contract?
detroittigerfan is offline   Reply With Quote
Old 08-14-2013, 06:12 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
leave the gap.. wall sheathing gets spaced hte thickness of a hand spike ( 3 1/2" common. roof sheathing is automatically spaced by the H clips that support the edges if your not using tongue and groove sheathing/
its specifically so it can expand and contract. mind you in some regions a larger gap is required
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mae-ling (08-14-2013)
Old 08-15-2013, 01:03 AM   #3
Maryland
Totally off topic... but why do you keep creating new user names and asking the same questions repeatedly? It's terribly annoying...
For anyone that hasn't pieced it together yet, "detroittigerfan" is "markharmon" and a number of other user names. Go back and compare posts, account creation date, etc. Sorry, ::end rant::
Pittsville is offline   Reply With Quote
Old 08-15-2013, 07:54 AM   #4
Rewards Points: 396
excuse me? This is my first time on this site!
Old 08-15-2013, 11:36 AM   #5
Maryland
markharmon ,07-24-2013
deck pier question
detroittigerfan, 07-26-2013
Shed playhouse question
markharmon, 07-11-2013
Wall layout Help
Wall question
sheathing blocks instead of h-clips, help needed roof52 Roofing/Siding 25 04-12-2012 11:38 PM
is my sheathing rotting? *pics* Nospammer Roofing/Siding 24 03-07-2012 09:06 PM
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 06:56 AM
Replacing Rotting Sheathing Behind Chimney. fredhead Building & Construction 4 11-19-2010 08:57 AM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 12:12 PM
