Old 01-15-2010, 09:02 AM   #1
shaving/planing drywall
I'm installing drywall now in my basement and I'm wondering what is the best way to shave/plane/trim the drywall edges especially when drywall goes in between walls and it does not go quite right in and need to remove about 1/4" or 1/8". I've been using utility knife and just run it along the edges but this gives me an uneven/wavy edges. I know it'll be covered later with tape but if there is way to make it straight, I'll take it.
kupalino is offline   Reply With Quote
Old 01-15-2010, 09:59 AM   #2
There's a tool called a drywall rasp. Very inexpensive.
Old 01-15-2010, 10:13 AM   #3
How does it work? I plan on cutting my drywall straight across horizontally and then down verticall. Just replacing part of my drywall as you can see here: How should I proceed? (Pics inside)
Thanks.
llckll is offline   Reply With Quote
Old 01-15-2010, 01:03 PM   #4
dIYHell
you just run the rasp along the side like you would plan a board, they work great. below is a link to show you what one looks like, you can pick one up just as cheap at any hardware store. http://www.amazon.com/Hyde-HYDE-0998...3578309&sr=1-6
Also for taping and mudding I found the following site very helpful on the proper methods, http://www.drywallinfo.com/
rocketdoctor is offline   Reply With Quote
Old 01-15-2010, 10:41 PM   #5
firehawkmph's Avatar
Those look just like a stanley surform tool. Probably the same thing. They do work great on drywall.
Mike Hawkins
[quote=rocketdoctor;383349]you just run the rasp along the side like you would plan a board, they work great. below is a link to show you what one looks like, you can pick one up just as cheap at any hardware store. http://www.amazon.com/Hyde-HYDE-0998...3578309&sr=1-6
firehawkmph is offline   Reply With Quote
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
