Old 07-14-2010, 05:21 AM   #1
sharing soffit space
is it ok to run water & gas & plenum all in the same soffit space?
space is tight and I wanna pack everything in as close as possible.
acerunner is offline   Reply With Quote
Old 07-15-2010, 11:20 PM   #2
Moderator
Is this new construction? Basement, garage, living space, existing room, type of room, unions on the gas lines, access water supply valves......
Be safe, Gary
Clothes taking longer to dry?
Old 07-16-2010, 12:34 AM   #3
this is a remodel in what was once a garage converted to living space. soffit will be through a laundry room & bedroom. I won't know about unions or valves until i open up the wall.
It is about a 10~15ft run so there might be a union. And I might have to "T" off to get gas for the dryer in laundry room.
I don't predict the need for a valve anywhere along the soffit. One end is the attached garage where pipes come in from utility, the other end is the kitchen above the bedroom so the pipes will run in the soffit in the bedroom and then go up into the kitchen, where the valves will be.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 12:16 PM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 07:36 AM
How to gently remove (aluminum) soffit? superfly Roofing 1 09-06-2009 10:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing 3 09-01-2009 08:47 PM
