Sharing Kings? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-13-2008, 10:25 PM   #1
Master Procrastinator
Sharing Kings?
Hey fellas,
I am installing 2 windows next to each other in the same wall. They are each 36" wide, and will be installed close to one another. I am wondering if I can use 1 king stud in between them, with a jack sandwiched on each side, or should I use a king for each window? It's on a 1st floor (garage) with only attic space above and a 22' truss span (load bearing wall).
mtaviator is offline   Reply With Quote
Old 01-13-2008, 10:36 PM   #2
Rewards Points: 5,336
There's no reason you can't share a king stud. The window on either side doesn't add to the load of the stud.
Ron
Old 01-14-2008, 12:28 AM   #3
Yea I suppose you are right, the jack studs are really carrying the load from the header. Thanks for clearing that up for me.
Old 01-14-2008, 12:33 AM   #4
ICF Construction
Size the header as if it was one giant window then frame between, no worries at that point.
Chris
Chris Johnson is offline   Reply With Quote
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 09:39 PM
