-   -   Sharing Kings? (http://www.diychatroom.com/f19/sharing-kings-15569/)
mtaviator 01-13-2008 10:25 PM
Sharing Kings?
Hey fellas,
I am installing 2 windows next to each other in the same wall. They are each 36" wide, and will be installed close to one another. I am wondering if I can use 1 king stud in between them, with a jack sandwiched on each side, or should I use a king for each window? It's on a 1st floor (garage) with only attic space above and a 22' truss span (load bearing wall).
Ron6519 01-13-2008 10:36 PM
There's no reason you can't share a king stud. The window on either side doesn't add to the load of the stud.
Ron
mtaviator 01-14-2008 12:28 AM
Yea I suppose you are right, the jack studs are really carrying the load from the header. Thanks for clearing that up for me.
Chris Johnson 01-14-2008 12:33 AM
Size the header as if it was one giant window then frame between, no worries at that point.
