Shaky Partition Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 10:26 AM   #1
framer
shaky partition wall
the wall is 20 ft long and 8 ft high, with drywall. and it shakes or unstable in the middle how can i do some kind of stablization. of this wall. this wall does not go to ceiling. there is a drop ceiling.
elpreacher is offline   Reply With Quote
Old 04-01-2013, 10:33 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Are the ends of the partition wall properly tied to solid walls?
The Following User Says Thank You to Maintenance 6 For This Useful Post:
elpreacher (04-01-2013)
Old 04-01-2013, 11:27 AM   #3
Roofmaster
Rewards Points: 2,172
Where is the wall? How is it supported laterally? Basement? Pictures? Location? Douple Top Plate with joints stitched?
Need a lot more info.
The Following User Says Thank You to jagans For This Useful Post:
Old 04-01-2013, 04:01 PM   #4
"You can do anything"-Mom
brockmiera's Avatar
Typically the partition wall framing is tied into the roof structure by way of some type of diagonal brace. I'll see if I can find a picture or architects detail.
brockmiera is offline   Reply With Quote
The Following User Says Thank You to brockmiera For This Useful Post:
Old 04-01-2013, 04:04 PM   #5
brockmiera's Avatar
I think a 2x2 angle maybe 16ga or 14ga would work depending on distance from wall to roof structure.
Old 04-01-2013, 04:58 PM   #6
Rewards Points: 12,804
My guess would be someone build that with a single top plate so it's able to flex where the butt joints are as well as all the other missing bracing.
Old 04-01-2013, 07:06 PM   #7
framer
two feet
Old 04-01-2013, 07:09 PM   #8
framer
this is the greatest answer to my problem, I will do this asap. thank you for thinking outside the box for me. david
Old 04-02-2013, 10:05 AM   #9
brockmiera's Avatar
Thats what we're here for. Let us know how it works out.
Need to move stud in finished partition wall juengl4 Building & Construction 7 02-18-2011 09:36 AM
Ceiling support for partition wall? hohadcr Carpentry 5 09-28-2009 09:38 PM
Loads on a partition wall acyate Building & Construction 8 03-01-2009 12:02 AM
A Garage Steel Stud partition wall PaliBob Building & Construction 8 02-16-2009 04:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
