Shadowbox Gate Support - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 08:14 AM   #1
Rewards Points: 528
shadowbox gate support
I have a 8ft wood shadowbox gate that is 42 inches wide and extremely heavy.Im looking for a idea as to a support in addition to the hinges.I set a new post and many hinges.Still sags (and may loosen in time)due to weight on hinges.It has pea gravel under it no concrete.Was thinking of a roller or wheel idea with maybe a small concreate slab where it closes(with a slanted strongtie in concrete) to take weight off the door when closed.
Any ideas are appreciated.Door weighs 90lbs ,more when wet.
hidden1 is offline   Reply With Quote
Old 05-27-2011, 10:32 PM   #2
Rewards Points: 528
roller will work
I guess ill just use a roller design directly under door with a concrete slab to roll up onto as closes..
Alterative ways to support main beam frizbplaya Building & Construction 8 01-28-2011 11:10 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 05:48 AM
Gate Design Question rocknroll99 Building & Construction 5 04-13-2010 07:46 AM
Driveway Gate Construction Questions KP Texan Building & Construction 3 07-30-2009 08:45 PM
