Old 06-15-2009, 07:06 AM   #1
Shadowbox 6' Privacy Fence
I am installing a 6' shadowbox fence in my back yard. I am using 4x4's for post, 2x4's for stringers(3 per section) and 1x6 for slats. I'm also having two walk thru gates and one 12 foot wide for back yard entry with my truck. I am using 6x6 post for that.
With all that being said, my question is:
1. Due to my yard having many trees with shallow root systems, I was not able to be 96" or 8 ft. between post. Average is 90 to 94 inches. When I install the vertical slats I am going to use a 4" spacer. To keep the appearance the same not all 4x4 post will be covered on the street side. Are they supposed to be?????
Sorry for the long question,
Archie
archbarb is offline   Reply With Quote
Old 06-15-2009, 08:37 AM   #2
Don't have an answer for you but I would be interested in hearing how you are going to make the 12' gate because I am about to do the same thing when I move into a new home next month.
dknarnd is offline   Reply With Quote
Old 06-15-2009, 11:51 AM   #3
There is a squared metal post available that will be flush with your stringers - makes it easy to conceal the posts with verticle slats. It's common for the fence posts to not always be equally spaced due to roots, rocks, or other - just vary the spacing of the verticle slats a bit as may be needed, the eye will not notice.
I like using metal posts with a wood fence - they last a long time whereas the wood posts are usually the first to rot/fail. With metal posts you'll probably replace the stringers and verticle slats a couple three times to the same post. Fast and easy to install as well - auger/dig all the holes, then insert a post, pour in a bag of fast setting post concrete, add water, plumb - go on the the next one... repeat...
Old 06-15-2009, 11:59 AM   #4
I assume a 12' opening with two 6' swing gates. I did similar once - got a fence place to make up the frame similar to what they would for a chain link fence, then attached the verticle wooden boards to it. Yes, was rather heavy - posts needed reinforcing and bracing. Then I had a couple pieces of 4x4 I cut to act as a supports for the loose end of the gates - I would lift a bit and they would wedge under - this so as the gates were not just hanging there always putting leveraged pressure on the posts.
Old 08-14-2010, 05:04 PM   #5
Smile
I was in the fencing business,commercial and residential for a long time! Suggest you go to a website and read the specifications for wood gate manufacturing which is not as simple as it sounds, and do it right. You can also call on a professional company which installs gates and see how they mfg and install them. Weight, material, sag, warping and bending, design, fasteners, stress, and torque are all issues. At the end of the day, I used KD douglas fir only for frames which is expensive. You can then use BC red or Atlantic white cedar finishing materials, or match your fence line pickets, boards, split, or stockade. Use mahogany only if it is going to be painted, varnished, poly'd or stained and therefore maintained. (More work but the best looking). The posts are all important. Forget 4 x 4's for gate posts. Even 5 x 5's and 6x8's have a tendency to twist, shrink or bend over time so I only use steel in two ways, either (s4s) square posts 3/16" or 1/4" wall X 5" or 6" pre-drilled so you can frame them with mahogany sides (from the grade up only), or a pre-drilled 6" I beam. Bury your posts 4' below the grade, in concrete;(do not pour concrete mix in the excavation and then add water some ready mixed compounds actually offer that as a mixing option in the instructions, but I say NEVER as it is a cheap and dirty way to install posts and very poor engineering resulting in no PSI rating at the end of the day) and at least as tall as the top of your gates, or taller for lamps, finials, or any other architectural ornamentation you wish to add. Don't forget the UF rated 12-3 wiring if you're going to attach lighting and an outside receptacle somewhere, or multi wire stock for openers if you decide one day to install electrically operated openers. There are always variations on any theme here, but this design always resulted in absolute customer satisfaction, especially if they were electrically operating gates with spans of 8' or more, which incidentally you could only do with wood along a livestock board fence. Sorry to rain on your parade, but there's a right way to do anything, and I've tried them all. That's how you learn. Good luck with your project. Bill
globalmkts is offline   Reply With Quote
shadowbox fence, privacy? johnnyboy Building & Construction 1 06-05-2009 06:50 AM
A few questions about building a wooden privacy fence in Florida Tineras Building & Construction 4 03-22-2009 02:38 PM
Privacy Fence on one side? caseydm Landscaping & Lawn Care 9 10-28-2008 11:13 AM
Privacy Fence Post 10' Apart wrldruler Building & Construction 6 09-02-2008 11:59 AM
Privacy Fence Gate Dallas Carpentry 8 11-20-2007 09:12 PM
