Old 01-22-2009, 01:52 AM   #1
Shade Sail structure
Hi I propose to erect a 5metre X 5 metre square Shade sail. To provide an interesting shaped sail I presume the 2 diagonally opposite posts will be of different heights. How much difference in height is necessary. Anyone know of a website showing post heights?
lemuzz is offline   Reply With Quote
Old 01-22-2009, 05:33 AM   #2
the Musigician
DangerMouse's Avatar
http://www.wholesaleshade.com.au/diy.htm
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-22-2009, 05:14 PM   #3
Thanks Dangermouse. As I said I have a 5 X 5 sail. Any suggestions how much height difference for the attachment points? Also as I intend using 2 X 200mm turnbuckles. Therefore 5metre sail plus turnbuckle equals 5.200 x 5.200 post centres at the ground. With the posts angled at approx 250 outwards at the top, this would give a 500 mm tension. Would the sail stretch this much? I intend using 100mm X 4mm wall galv pipe.
Old 01-22-2009, 06:20 PM   #4
the Musigician
did it come with directions? instructions? specs? what the heck is a mm?
i'd go at least a foot or so difference for effect.
seriously... it should stretch, but can't you make the posts adjustable?
then it wouldn't be a problem at all.
DM
Old 01-22-2009, 07:47 PM   #5
sorry for the measurement but Kiwi's can only count to 10 as they only have 10 fingers hence the metric size. OK. 5.000m equals about 16feet. 200mm turnbuckle equals 8 inches 250mm offset equals 10inches. Therefore 16feet plus 8" (plus the offset of 10"each post (the posts leaning outward) to stretch the fabric. Would this be too much? or would I need a turnbuckle on each post. If I need a turnbuckle on each post will 10" be enough as each turnbuckle would use up 8" leaving hardly any stretch of the fabric. The instructions say to allow 10% of the sail measurement to accommodate anchoring devices, but nothing to allow to tighten the fabric that's about all it says. The posts will be set in concrete so I need to know before i start.
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
Full shade grass MillerClemsonHD Landscaping & Lawn Care 1 03-26-2007 10:30 AM
kit metal building as addition structure weaver Building & Construction 9 08-08-2006 10:59 AM
