Hi, my sidewalk is not broken, but settled on one side only (the side near the lawn is fine, but the side near the road is settled by 4 inches). Apart from the settling, its not broken. The settling is pretty much even along the perephery (along the road side).
How do I fix this? Do I have to break/remove the entire sidewalk and then pour the new concrete mix? or can I use the same settled sidewalk as the base and pour concrete (quikrete) over it? What will the problem be, if I do it the this way?
Please give me a solution... thank you all. I had to post this in building & construction as I couldn't get anyones attention in the landscaping section.
