setting tub in mortar?
I am installing a fiberglass bathtub. From the searching i have done it is recommended to set it in a bed of mortar for support. Should i lay down some 6 mil plastic or is it ok to put mortar directly on the wood subfloor? Thanks and feel free to share any other advice about setting tubs!
I put plastic over the mortar to keep it away from the fiberglass. I can put the tub down and stand in it to set it, then raise it up to make sure there are no low spots and the mortar doesn't stick to the tub.
Ron |
Thanks Ron. So i don't need to worry about the concrete ruining the sub floor from the moisture in the concrete?
Only thing I have noticed is it seems to set faster when on wood than on plastic. Maybe it was just me. Also - I built a little dam out of cardboard to keep the mortar where I wanted it. stapled it to the ply deck.
| All times are GMT -4. The time now is 02:22 PM. |
