Setting Post Straight - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2006, 04:04 PM   #1
Rewards Points: 150
setting post straight
I have to put 4 post in the ground for a stairway that is going to go down a bank. 2 on top of bank and 2 at the bottom. How do I make sure they are in line with each other? There is no reference point to measure off of. Thanks.
econdave is offline   Reply With Quote
Old 06-12-2006, 05:51 PM   #2
Master Craftsman
Big Dave's Avatar
I don't know what kind of distance you are talking but I would set the top two post where you want them and then measure straight out the required distance and then plumb down to get the desired distance. As far as square diagonal measurements out to bottom two post will also get you square. I think that is plain enough, if not somebody else will come alon with a better answer.
Dave.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 06-16-2006, 04:09 PM   #3
Rewards Points: 150
Big Dave? for my post
when you say plumb down, what do you mean? a plumb bob? I dont know why I had a brain cramp about getting them square, thanks for the mental massage. Sometimes the easiest things I read to far in to...
Old 06-16-2006, 06:49 PM   #4
General Contractor
joasis's Avatar
A transit if you have access to one works wonders.
joasis is offline   Reply With Quote
Old 06-16-2006, 07:04 PM   #5
Master Craftsman
Big Dave's Avatar
You can use a plumb bob or what I would do is get a board long enough to put a level to and hold plumb and measure out to it.
Old 06-17-2006, 01:20 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I 2nd that vote.
- Build Well -
wood fence post farrington135 Building & Construction 11 05-17-2011 03:32 PM
Post mounted electrical receptacle NIlRO Electrical 13 04-19-2010 03:20 PM
Setting Fence Post cibula11 Building & Construction 2 06-22-2007 10:05 AM
Post in or post on concrete cibula11 Building & Construction 5 06-07-2007 10:39 PM
