Old 01-10-2008, 01:52 PM   #1
Setting a deck beam directly on footings
Lots of good information on this site. I have been sweating all the details on attaching a deck ledger to a lower portion of the house when a light bulb came on. Don't connect it at all. Free standing makes a lot of sense, you don't compromise the house at all.
The deck is low enough (2-4' from deck surface to grade) where I can raise the 12" round footings right up to the beam (4x8). When placing the anchors in the concrete, it doesn't seem like you have a lot of wiggle room. A post you can cut to exact height and if the beam is slightly bowed a post can be adjusted laterally. However I thought there might be a problem with short posts splitting.
I would probably line up all the metal anchors along a taught line but the beam more than likely wouldn't drop in. I could connect the anchors to the beam first and set them in concrete in one finished assembly. That would require a lot of guys handling the concrete real fast.
How would you approach this? Deck dimensions are 8x16'
ovahimba is offline   Reply With Quote
Old 01-10-2008, 02:57 PM   #2
I've never tried it but if you place the beam in position with some temp braces before the pour you'ld have all the time you want for the pour. Put together a small plywood chute to help direct the crete into the smaller opening. Make sure you vibrate or rod around the metal anchor.
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Concrete Deck Footings Bumpy Melanie337 Building & Construction 6 09-24-2007 09:11 PM
Deck support beam has twisted Brian Ward Building & Construction 5 07-27-2007 12:03 PM
Deck post footings Outbacker Building & Construction 8 02-11-2006 06:20 PM
