Is This A Serious Problem - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-04-2007, 07:52 PM   #16
The floor in the kitchen is old school linoleum.
I think all the floors in the unit needs to be replaced.
sponge is offline   Reply With Quote
Old 01-04-2007, 08:13 PM   #17
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You also have to realize that you are only seeing what is on the surface.
Generally, once the walls are 'opened up'.....it is not uncommon to find additional issues that need to be taken care of, especially in homes that look the age of the one you show in your pics.
i.e. -
New plumbing connections and lines needed, rotted floors or framing members, bad insulation, leaking windows.....etc...
Just something to be very aware of.
We come across it all the time when doing remodeling work.
We even have sub-points included in our contracts regarding our procedures for handling "discovered-damages" while doing the other original contracted work.
- Build Well -
Old 01-04-2007, 08:28 PM   #18
AtlanticWBConst.
Thank you very much for the heads up.
Old 01-04-2007, 10:29 PM   #19
Anyone think this is a money pit?
Old 01-05-2007, 03:57 PM   #20
Have you purchased it yet or are you still negoitiating the price?
redline is offline   Reply With Quote
Old 01-06-2007, 04:03 AM   #21
Wow! It's definitely a fixer-upper! If you do buy it, keep the chatroom updated as you repair and redo things. I'd enjoy seeing this project as you work on it.
Not Sure is offline   Reply With Quote
Old 01-06-2007, 12:45 PM   #22
NH Builder
If you're going to redo the bathroom you should be able to see if the tenants bathroom is leaking above when you rip out the old ceiling. You really are going to want to gut that bathroom and start over. I would say the 6k starting is a good baseline, but bathrooms are quite expensive and things can escalate quickly!
Good luck
NHBuilder is offline   Reply With Quote
Old 01-07-2007, 09:43 AM   #23
The repairs seem to be an average remodel in the bathroom unless issues are discovered inside the walls.
How old is the building?
Do you know if the plumbing has ever been upgraded?
How old is the electrical?
The repairs that you make to the bathroom and kitchen should increase the value of the property. When you decide to sell then you may recoup from 75 to 90% of the cost that you have put into the kitchen and bathrooms as long as it is quality work that appeals to many new buyers.
Is the area desirable?
Are the other units increasing in value?
Are the rest of the units in better shape then this?
Simple real estate formula -Buy the worst looking house on the block and improve it to the value of the other homes. Unless the cost to improve costs more then the final value.
Old 01-07-2007, 09:44 AM   #24
Do you know if they contain asbestos?
Old 01-07-2007, 09:46 AM   #25
You could place an offer than is reduced to cover some or most of the repair costs.
Old 01-07-2007, 07:36 PM   #26
Still thinking about putting an offer in...
We would have to hire someone to do almost all the work.
I dont know how old the building is but I'll try to find out.
I'll also answer these questions as I found out more info.
The area is desirable, theres plans for luxary condos across the street.
The unit upstairs was renovated by a young couple and looks great and has a lot of character
Thank you for the input and help!!!
Old 01-09-2007, 08:18 PM   #27
Are you able to ask the upstairs owners how much they paid for their new bath to get a general idea on what the expense may be?
You may even be able to ask to have the company that did their remodel to give you an estimate on your remodel in order to get a better idea on what it will cost to update yours before you submit an offer.
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 08:08 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 07:24 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
