Serious Brick Wall Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2011, 04:55 PM   #1
Serious brick wall problem
An addition was made to a two story brick horse barn. An opening was cut out for a first floor extension (roughly 12w x 8 x 8); the second floor wall was supported by adding beams under the brick - and into a variety of notches in the wall.
The beams, I believe, are rotting - and the second floor bricks/mortar wall is showing large gaps. The extension roof joint keeps opening and allowing rain in to the support beams.
How can I replace the beam(s) with steel? How can I lift and hold the upper wall while doing so?
Normie is offline   Reply With Quote
Old 06-25-2011, 05:32 PM   #2
Rewards Points: 582
Can you put some photos on?
stuart45 is offline   Reply With Quote
Old 06-25-2011, 07:12 PM   #3
DIY staff
Rewards Points: 7,174
Please a photo---and a country.
Old 06-26-2011, 12:32 AM   #4
Sorry
No photos available.
Will try to add some drawings.
Pennsylvania, USA.
Old 06-26-2011, 05:43 AM   #5
Rewards Points: 582
Without seeing the job I would guess that you need to knock out some holes above the beam and put in some needles supported by acro props as shown below, although these are below the beam. Once the wall is supported you can replace the timber one with steel and build in the holes.
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 09:07 AM
Hanging a joist in an 1895 brick wall billydwilliams Building & Construction 4 03-28-2011 04:09 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 10:41 AM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 08:41 PM
Peplacing rotten framing against brick wall minnjh Carpentry 2 07-01-2009 04:21 PM
