Semi Exposed Sill? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2011, 08:20 PM   #1
Rewards Points: 358
semi exposed sill?
I went with a friend to look at a new house today, it is a brand new house. When walking around it and checking it out, I noticed that the exterior sheathing stops right at the bottom of the sill plate and then the bottom trim board sits right on top of that, there is no flashing on the bottom side of the trim board either (not sure if that is a requirment) But the thing is, it was raining and water would go down the trim board and would hit the underside of the trim and the run back to the sill area. I can not actually see the sill plate, but I can see the top of the foundation wall. I am sure overtime this could possibly rot out the sill plate or sheathing? Surprisingly the builder was at a house next door and he asked us if we had any questions. I asked him about this, and he said if my friend got the house and this worried him he would run a thick bead of clear caulk from the underside of the trim/sheathing to the foundation and that would keep everything dry.
It sounds like a good idea, but at the same time it seems like if any water got behind the siding it would then be trapped.
What are your guys thoughts? If this doesn't make since I can draw up a sketch.
cbzdel is offline   Reply With Quote
Old 09-17-2011, 09:39 PM   #2
Rewards Points: 5,336
I think the "builder" is an idiot. If that's the crap you see, imagine what's hidden behind walls and under floors.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
AndyGump (09-17-2011)
Old 09-17-2011, 09:54 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
The thing I love about Ron is his eloquence and tact.
And he is right most of the time.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Tom Struble (09-18-2011)
Old 09-18-2011, 12:48 AM   #4
Rewards Points: 358
regardless of the builders quality, with the price being the price it is chances are he may go for it, what would the answer to the question at hand be?? Is it really even an issue? What would of been the correct way to install it? And whats the remedy?
Old 09-18-2011, 08:31 AM   #5
kwikfishron's Avatar
Rewards Points: 606
Yes it is a issue and caulking is not a solution.
You donít mention what type of siding but it could probably be resolved with a properly flashed trim detail extending an inch or so below the plate line.
Pictures would help.
kwikfishron is offline   Reply With Quote
Old 09-18-2011, 10:12 AM   #6
Framing Contractor
Yes, it is an issue..a big one. It should have been flash BEFORE the siding was put on.The flashing should be behind the trim board and over the top of the foundation and down the side of the foundation about an inch.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-18-2011, 10:53 AM   #7
Rewards Points: 358
Here is a quick sketch that I put together.
Also it only seems to be a problem on one wall. It seems that if it needs to be fixed, it seems like this the whole side of the house would need to be re-sided, because it would not look right if you where to just drop the trim board an inch or so.
Old 09-18-2011, 02:41 PM   #8
Framing Contractor
You can use a 1x10 and rip it down to 8-1/2" Are there corner boards on the house?
Joe Carola
Replacing Termite Damaged Sill, Joists, and Girders bd_dc Building & Construction 0 02-01-2010 11:21 PM
How short can sill plate pieces be ? tuckerz Building & Construction 2 10-04-2009 03:41 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
Door Sill Flashing Pondo13 Building & Construction 1 08-19-2009 06:15 AM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 09:43 PM
