Sell Me On The Zip System - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 08:59 PM   #1
kwikfishron's Avatar
Rewards Points: 430
Sell me on the Zip System
Is this a superior product compared to traditional methods?
What are the cost comparisons to this and the standard sheathing/wb/flashing detail?
How do the flashing details work, or do you need any?
What about the seams? I know you tape the seams but…..must be some darn good tape.
http://www.zipsystem.com/
kwikfishron is offline   Reply With Quote
Old 04-16-2011, 11:26 PM   #2
Registered User
Rewards Points: 5,498
Haven’t used it yet. With a perm rating of 13-16 on the outside coating and even less on the tape, I would research it some. I would push a rain-screen system with f.c. or Cedar, unless down South with >20” rain. Or at least ply or OSB and stucco wrap w. wrinkles to divert water, even behind vinyl. http://docs.google.com/viewer?a=v&q=...RvUBSlz4b5thmA
That gives you an all important slight gap between sheathing/siding to drain the sun-driven moisture from behind the f.c.http://www.buildingscience.com/docum...d%20in%20walls
You would not get that w. Zip unless rain-screened. It is a denser product than OSB, holds the edge swelling better; http://www.utextension.utk.edu/publi...files/W176.pdf
If it ever did get wet, would take a looong time to dry because of the low perm coating. I used to push Typar over Tyvek, used to…. Tyvek- 58p., Typar- 16p.
Tyvek and OSB, saturated test; took >15 days to get to 10%----low perm wrap (similar to Zip) took 65-70 days to 10%. Page 15; http://repository.tamu.edu/bitstream...pdf?sequence=4
Same page; no mold on OSB/Tyvek---83% mold on 11perm. wrap- similar to Zip.
Remember that’s with a water leak not minimal inside/outside diffusion. You don’t want to see the Ply vs. OSB………I’d have to search library for it. Like any engineered wood, keep it dry, it’s fine. Not with a low perm coating though…..
pp.17, above conclusions--- 18-24p window. Hmmmm.
Sorry couldn’t help you more.
Gary
Old 04-17-2011, 06:11 AM   #3
KemoSabe
loneframer's Avatar
I've used it on a roof. It seems like a decent product, but the edges WILL swell if exposed to wetting for too long.
The tape is super tacky, but must be rolled for proper bonding. If you use the system, I recommend the dispenser highly.
I'm still not convinced on wall applications, not only for permeability reasons, but for proper flashing details at critical spots.
Call me crazy, but I'm still a fan of #30 ASF, especially over OSB. The Variable Permeability of felt is a distinctive feature that "holds alot of water" in my book.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 04-17-2011, 11:24 PM   #4
Registered User
Zip (or OSB) should never be used with spray foam inside. The moisture has no where to go but into the sheathing and can not dry to the outside with the low perm coating; “When placing a foam product in an
exterior wall assembly, ensure that the
moisture flowing through the foam will
not affect other materials. This could
happen when moisture is trapped in a
moisture-sensitive material, such as
plywood or OSB, and drying is prevented
by the layer of SPF. It could also happen
when moisture accumulates in the outer
layer of the spray foam, which could
damage moisture-sensitive materials
such as sheet metal.” http://www.earthane.com/ctu32e.pdf
Of course OSB would have a high perm.WRB rather than a low perm. coating, making it dry faster.
I believe we will see more of the product used simply because it easier to get a WRB with it, though it’s still on an OSB backer, even denser- essentially a vapor barrier. Then there is the sheathing temperature/dew point concern with OSB (Zip). How many builders will be installing only enough (past min.code) exterior rigid insulation rather than insulating to lower the dew point of the inside face of the sheathing. Footnote “H”; http://publicecodes.citation.com/ico..._11_sec002.htm
http://www.greenbuildingadvisor.com/...foam-sheathing
Figure one and be surprised; http://www.greenbuildingadvisor.com/...ally-necessary
http://www.greenbuildingadvisor.com/...wall-sheathing
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
kwikfishron (04-18-2011)
Open Hydronic Heating System... how / need to bleed? MtnMan7 HVAC 1 11-19-2010 03:51 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 03:26 PM
Which heatings system should I go with? keano016 HVAC 5 12-01-2009 02:53 PM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 07:31 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
