Segal Deadbolt Lock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 09:46 PM   #1
segal deadbolt lock
I opened the back plate of my segal deadbolt lock & dropped it. there are 3 pieces that fell out : A spring, the brass locking mechanism & a silver piece(?). Any clue on how to put the pieces back so I dont have to buy a new one?
ezg928 is offline   Reply With Quote
Old 02-03-2009, 12:07 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
The silver piece has a hole that fits over a pin on the bolt unit. The spring coils behind the silver piece and forces it up agianst a stop on the bolt unit. Place the spring, then the silver piece over the pin. Hook the spring on the bolt and the silver piece. Hold the assembled pieces and test to see that the silver piece moves easily and that the spring returns it. Lay the assembled pieces back into the case. The knob on the case has a cam lobe on it the depresses the the silver piece and moves the bolt in and out of the case when the knob is turned. There will also be a similar cam lobe on the back plate. Make sure that neither of these lobes are trapped behind the bolt unit. Then lay the back plate into the case and put the screw back in. Don't take any more of these apart. Contains no user servicable parts.
Deadbolt issue jkrodger Remodeling 5 01-27-2009 04:25 PM
Dodge Caravan 2005 driver door lock Wildie Automotive Repairs 11 11-20-2008 03:18 PM
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 10:45 PM
garage door lock jack_j General DIY Discussions 1 12-27-2006 06:40 PM
Deadbolt suddenly won't retract Squeeealer Carpentry 1 07-14-2005 08:20 PM
