Seeking Recommendations For Fireblocking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-22-2014, 09:31 AM   #1
Rewards Points: 113
Question
Seeking recommendations for fireblocking
Hi Folks,
I just had my framing inspection for a diy basement I'm finishing and failed due to lack of fireblocking. I had no idea that it was needed and why. I spent last night reading and I think I'm ready to go except for one tricky spot.
I have an existing 2x4 wall that had plumbing. I think may be able to scab a board in near the pvc pipe, but I'm looking for advice on how to handle this gap. I've got a couple of pictures attached that should tell the story.
Thanks in advance,
Matt
Seeking recommendations for fireblocking-dsc03621_resize.jpg   Seeking recommendations for fireblocking-dsc03620_resized.jpg
mklein49 is offline   Reply With Quote
Old 02-22-2014, 12:05 PM   #2
Rewards Points: 256
You can fill the area around with fire block spray foam. home depot carries a 3m brand i used plenty of times never had a problem with inspector. I heard roxul insulation works too but never talking to inspector about it. From what i hear you can stuff the whole cavity with it instead of trying to add 2x4 or plywood and then caulking the gaps with fire caulk.
JustinK is offline   Reply With Quote
Old 02-22-2014, 03:10 PM   #3
Rewards Points: 113
I ended up filling in where I could with 2x4's. Now I need to fill the cavities.
I'll check at home depot for the 3m product.
Seeking recommendations for fireblocking-dsc03626.jpg   Seeking recommendations for fireblocking-dsc03625.jpg
Old 02-22-2014, 04:52 PM   #4
Rewards Points: 256
Get some fire caulk too. You need to caulk all the wires going through the top plate.
The Following User Says Thank You to JustinK For This Useful Post:
Gary in WA (02-22-2014)
Old 02-22-2014, 10:12 PM   #5
Registered User
Rewards Points: 4,924
How to fireblock framing
Read and hit "next section" 3 more times; http://publicecodes.cyberregs.com/ic...002_par017.htm
"7. Wood furring strips or other wood framing members attached directly to the interior of exterior masonry walls or concrete walls below grade except where an approved vapor retarder is applied between the wall and the furring strips or framing members." from; http://publicecodes.cyberregs.com/ic...9_3_par203.htm
Gary
PS. check locally; http://www.reedconstructiondata.com/...odes/missouri/
Old 02-23-2014, 04:28 AM   #6
DL's husband's Avatar
I'd suggest that you contact the inspector and ask him for some advice and recommendations to meet or exceed the township's building department's requirement.
Fire blocking is basically nothing more than some additional horizontal boards between the studs and/or sealing the gaps through which piping and wiring run through the sole and/or top plates.
In your case, looking at your photo's it may also include the gap between the existing masonry walls and your new framing.
DL's husband is offline   Reply With Quote
Tags
basement , fireblocking
Portable Generator/Transfer Switch Recommendations mgh-pa Electrical 21 09-26-2013 08:50 AM
Wanted recommendations LED light to replace 2' fluorescent jrsavoie Electrical 0 11-08-2012 10:59 AM
recommendations for beverage centers? bbo Appliances 0 02-11-2012 04:04 PM
Shower Pan Recommendations Craig2010 Kitchen & Bath Remodeling 6 10-22-2010 07:03 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
