Security...all Screws Created Equal? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 01:28 PM   #1
Rewards Points: 83
Security...all screws created equal?
Hi,
Due to an increase in burglaries in my neighborhood I did some searching and saw that someone recommended replacing the screws around the strike plate in the door jam (I hope the terminology is close enough) with longer ones so as to enter the door frame.
Mine are currently an inch, it looks like I can do a 2 inch without messing with the side panel windows.
1)So the actual question is...if I use a coarse DRYWALL screw is that ok?
I know they aren't stressed for cabinets, etc....so how would they fair to someone trying to kick in the door?
2)I also read that to prevent a sliding door from being lifter off the track (newer door) one can drill into part of the track into the door and insert a pin (probably a small nail in my case.
IS there any seal I can damage on the door itself?
The track is a molded plastic as is the perimeter of the sliding door.
Thanks for all suggestions...
bergerdude is offline   Reply With Quote
Old 10-05-2010, 03:17 PM   #2
Rewards Points: 258
With regard to your first question, I have found drywall screws to be brittle. They will snap off easily if used as you propose and the door is forcefully hit. Even deck screws would be an improvement over drywall screws. There may even be something stronger. Check with your local home center or a real hardware store, if you can find one that has not been driven out of business by the big box stores.
retired guy 60 is offline   Reply With Quote
Old 10-05-2010, 06:02 PM   #3
I was at a garage sale and picked up some stainless steel screws. I was surprised they bend like a nail. I'd imagine they would be good to use for the strike plate. They would hold well, and bend when force is applied. The box stores have ss screws.
I wouldn't use a s/r screw, they snap.
As far as the patio door, don't know but if you're drilling plastic not much holding power, better ask around.
eastside is offline   Reply With Quote
Old 10-05-2010, 07:00 PM   #4
Rewards Points: 5,336
Originally Posted by bergerdude View Post
Hi,
Contact your local police dept. Many dept's will come to the house and advise you of weak points in your house.
Personally, I would go into your backyard and pry open a window.
Ron
Old 10-06-2010, 01:42 PM   #5
Rewards Points: 358
When you said this:
"it looks like I can do a 2 inch without messing with the side panel windows"
I instantly thought, whats the point, sounds like you have door sidelights.. If you were a burgler and wanted to get into a house, if you kicked the door and it didnt budge, and you really wanted it, you break the side light and reach in and unlock the door.
cbzdel is offline   Reply With Quote
Old 10-06-2010, 02:06 PM   #6
Rewards Points: 258
To solve your sliding door dilemma, I'd suggest a low tech method of taking a piece of hardwood about the size of a furring stip and cutting it so that when laid down horizontally over the bottom track the slider can't budge. No need to drill a hole and this method is tried and true.
Don't assume that stainless steel screws are better than other fasteners as one poster noted. I bought some stainless steel deck screws from Home Depot that were impossible to use as the heads quickly stripped when I tried to drive them into PT lumber. They were imported and the stainless steel may have been low quality.
Old 10-06-2010, 09:40 PM   #7
Rewards Points: 83
Thanks for the responses.
We do have those small windows on the sides of the doors. I don't know why builders continue to do this stuff....pretty dumb.
Our old home had them but I was able to change out a keyed (both sides) lock to prevent simply breaking and turning the latch.
This home I have not found a good substitute, have instead just gone for a simple interior slide latch that would be difficult for Stretch-R-Strong to reach.
All our horizontal doors and windows have 1/2" PVC (white goes with the cookie cutter builder home) to serve as the "broom handle" in the slider.
Can Sliding glass doors move more than 1/2" in the track? This is what I am unsure of?
Our vertical lift windows only have the integrated lock...I could friction fit more 1/2" pvc wedgy bar vertically....but I'm not sure how great that would be. Any ideas?
Of course if someone wants in they can throw the patio furniture through the window...until the motion picks them up.
I removed a screw out of the catch plate and it is an inch....not ideal, but at least it wasn't a 1/2" decorative screw.
Thanks again...
Old 10-07-2010, 07:49 AM   #8
jlhaslip's Avatar
Rewards Points: 2,204
According to the Building Code in my area, any window within 36 inches of a door needs to be Tempered/Safety glass.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
entry door security? cbzdel Remodeling 8 10-07-2010 11:38 AM
Security screen door dangerp Carpentry 4 09-22-2010 07:02 PM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 08:56 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
Are all hardwoods (flooring? created equal??? ahnniem Flooring 2 01-28-2006 01:17 PM
