Securing Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2010, 05:50 PM   #1
securing walls
I just took down a wall between my kitchen and living room but left up 5 feet so that i could make it into a breakfast bar, only it is very shaky. How can i secure it so that it doesn't move enough to install a countertop on it? In the furture i want to put cabinets behind it but for now it sits alone with one end attached and the other open. thanks for any and all help!
jmconfusior is offline   Reply With Quote
Old 05-26-2010, 07:42 AM   #2
Rewards Points: 156
How wide is this wall? Pics may help. Is there a doorway on one side? If I were you I would take the whole thing out and start from scratch. The wall was probably originally supported by the ceiling and the floor, which means you removed half of the support.
Branden is offline   Reply With Quote
The Following User Says Thank You to Branden For This Useful Post:
jmconfusior (05-26-2010)
Old 05-26-2010, 09:03 AM   #3
firehawkmph's Avatar
Rewards Points: 1,884
Jm,
Those little wing walls are always tough to secure. Couple of thoughts:
If you have access below, you could strip off a section of drywall to expose the outermost bay of your wing wall. Drill holes in the top and bottom plates through to the basement. Counter sink the top hole and install a piece of 1/2" allthread (threaded rod). Put a piece of 2 x 4 blocking underneath from the basement side and crank it tight.
THe other thing I have done is install 1/2 cdx on one side of the wall. Course you would have to strip the rest of the wall to do this. If you wall has one side that dies in a corner, you might be able to do this. Cover the cdx with some 1/4" drywall. Make up a nice wooden shelf to go on top for now. This will give you a place to stop your cdx/drywall side.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Old 05-26-2010, 10:08 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
Add another 2 x at the end of the wall (stud), but put it thru a precut hole in the floor. Attach directly to floor joist if you can, otherwise use blocking same size as the joists.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
Old 05-26-2010, 07:19 PM   #5
it is a concrete floor and yes the support i guess was removed. if i start from scratch should i use a something bigger like a 2 x 6. will it make a differecne?
its sorta small 46 inches high and 5 feet long. there is no door.
Old 05-27-2010, 12:05 PM   #6
What about building a narrow (18-24") end wall perpendicular to your existing shortwall?
gdoucette is offline   Reply With Quote
Old 05-27-2010, 12:08 PM   #7
Rewards Points: 156
Post some pics
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
