Securing PT Wood Against A Brick Facade - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 04:47 PM   #1
Rewards Points: 1,088
Securing PT Wood Against a Brick Facade
IF you wanted to secure a PT stud or board against a brick facade, would you drive a tapcon screw or anchor screw through the mortar joint or the brick itself?
BTW, I'm using this piece of PT to secure corrugated piping that hooks to the gutter downspout, not a fence or anything heavy.
handy man88 is offline   Reply With Quote
Old 06-11-2009, 06:01 PM   #2
Old School
cabinetman's Avatar
I would go into the brick itself.
cabinetman is offline   Reply With Quote
Old 06-15-2009, 12:27 PM   #3
When dealing with mortar there are no published holding values for tapcons because the quality of the mortar mixed is not known. The holding values of brick are alot more reliable. I always try the screw in a non descript area first. If I get a bite and the tapcon gets fully embedded I then continue on to my application.
Bronx is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Replacing Brick with Wood siding HLB Carpentry 1 06-11-2009 11:17 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
