Securing Posts To Cement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 08:41 PM   #1
Question
Securing posts to cement
I need to replace the railings that were on my front porch (made of cement). I plan to use PT wood in a balluster design. However, I'm at a loss as to how to secure the posts to the porch without the brackets showing. The only thing I can think to use are angle brackets but I don't want them showing. Nobody seems to make a bracket that the posts can slide into and then hide unless I go with aluminum but the cost is prohibitive. Does anyone have any ideas on how I can tackle this problem? Is there someone out there that makes a product that will do what I want that I just haven't found yet?
Thanks in advance
Bodrey is offline   Reply With Quote
Securing Electrical Outlet in Unfinished Room - Cement smohamed9 Electrical 2 04-04-2010 09:53 AM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
upright posts in a wet cement slab shellgirl74 Building & Construction 7 03-19-2009 12:06 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
