-   -   Securing Luan to bathroom plywood floor (http://www.diychatroom.com/f19/securing-luan-bathroom-plywood-floor-19697/)
Happy Hiker 04-09-2008 10:14 AM
We are laying DuraCeramic floor tile on a new construction bathroom floor. What method should we use to secure the luan to the plywood floor? We don't own a compressor and would prefer not to use a high pressure staple gun. Can we use adhesive? Underlayment nails? This is a small 5X7 room.
Thanks in advance for sharing your advice!
Happy Hiker
troubleseeker 04-09-2008 10:03 PM
Happy Hiker
Do not use anything. Return the laun and get a proper underlayerment material, as laun is not approved for underlayerment for any type of floor, by any flooring manufacturer that I know of. You can then secure the backer board, which ever product you decide on, by bedding it in thinset and hand nailing with either ring shank underlayerment nails of galvanized roofing nails.
HomeSealed 04-09-2008 11:39 PM
Second that!
Ron6519 04-10-2008 09:07 AM
This stuff is vinyl tile that looks like ceramic. What does the manufacturer say about luan as an underlayment?
Ron
Dura ceramic website listing:
Subfloor and Preparation
All subfloors should be clean, smooth and dry.
Install over:
— Double layer wood construction over joists or trusses on 16” centers
— Single layer APA rated Sturd-I-Floor T&G Panels, minimum
23/32”over joists or trusses on 16” centers
— APA Underlayment Grade Plywood
— Oriented Strand Board (OSB)
— NPA Rated Particleboard
— On, above and below grade concrete
— Gypsum topping and lightweight concrete
— Single layer, fully adhered resilient flooring
— Old adhesive residue and paint
I don't see luan.
Happy Hiker 04-10-2008 10:43 AM
Thanks!
Okay, it's back to the drawing board for us. We were told by a big home improvement store to use luan. We'll return it and start again. Thanks to all who took time to give us advice.
Ron6519 04-10-2008 12:15 PM
Why can't you just put down the thinnest exterior grade ply you can find? If you like the floor, just return the luan.
Ron
Happy Hiker 04-10-2008 01:41 PM
The builder used ADVANTECH (59 year limited warranty). It looks like plywood and it looks good. Maybe we don't need an underlayment?
Ron6519 04-10-2008 05:02 PM
Subfloors are not good surfaces for vinyl products. You need a smooth properly fastened underlayment for a successful job. The seams need to be filled and sanded. The fasteners need to be countersunk, filled and sanded.
Proper underlayment, glued, screwed ,filled and sanded. Any short cuts and you'll be ripping it up within a year.
Ron
