Securing Jack Post To Concrete Floor. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-22-2014, 08:37 AM   #1
Rewards Points: 99
securing jack post to concrete floor.
I'm putting a jack post to support a beam in an addition per the approved plan, there is a footing already under the concrete floor for it, and i'm using lag bolts to secure the top to the beam. to secure the bottom plate to the floor do I need to use a sleeve anchor? can I get away with masonry nails? is there another option I'm missing? thx!
yellowkid is offline   Reply With Quote
Old 05-22-2014, 09:01 AM   #2
Rob
Robpo's Avatar
Rewards Points: 826
Your building inspector could answer that. They want anchors in everything now days. Use to be you could run a bead of construction adhesive and shoot some masonry nails to hold walls.
Robpo is offline   Reply With Quote
Old 05-22-2014, 02:15 PM   #3
Civil Engineer
Rewards Points: 4,854
Since you have an approved plan, there should be a note on the plan describing the required method of attachment of the jack to the floor. If there is no description, call the designer or the building inspector. Typically for a retrofit, the designer will want either epoxied in place bolts, sleeve anchors, or an expansion anchor, but they might accept a Ramset type anchor. Doubt that masonry nails would be acceptable.
Engineered hardwood over vinyl tile - am I being unreasonable or am I getting screwed photopeter Flooring 25 02-01-2014 11:41 AM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 08:58 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
