Securing A Half Wall - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 08:00 PM   #16
AHH, SPANS!!!
Rewards Points: 1,166
Originally Posted by cbaur88 View Post
So I'd be making it a double wall and attching them together with blocks? Gotcha! Good thought and was thinking something along thos lines but was trying to avoid that and see if there was some magic bolt that would secure this thing more then the dry wall screws. Thanks for Advice!
spax and other structural screws have quite the magic
hand drive is offline   Reply With Quote
Old 02-17-2013, 10:45 PM   #17
Rewards Points: 960
A decorative book case, cabinet, or planter would have looked nice there.
That wall will always be wobbly until you sheathe it. I have seen people brace such wall with diagonal metal bracing also. I would sheathe both sides with 1/2" osb, then sheetrock it.
You can start by sheathing one side and see how that feels.
cleveman is offline   Reply With Quote
Old 02-18-2013, 08:17 AM   #18
AHH, SPANS!!!
cleveman has the right idea. the sheathing would tie the wall to the wall plate also and stop the play there where they join.
Old 02-18-2013, 05:43 PM   #19
Rewards Points: 278
Thumbs up
Thanks !!
Thanks everyone for the input. I had a revalation last night laying in bed. Put some heavier duty L brackets at the front where it was wobbly. Man did it make the world of difference. This thing ain't going anywhere it's solid as can be, what a major major difference. I chiseled out the 2x4's so the L would set back and not interfear with the drywall. Thanks again everyone for the help, problem solved!!!!
cbaur88 is offline   Reply With Quote
Does the bottom half of basement wall has to be insulated? Johnny Ren Building & Construction 29 12-16-2010 09:18 PM
Tiling an outside corner to a half wall roadrunner75 Tiling, ceramics, marble 3 10-27-2010 04:02 PM
Ideas for Temporary half wall type partition with gate. lenpharleyd Remodeling 4 12-27-2009 06:37 AM
Framing a half wall for a bar QueenL Building & Construction 12 04-02-2008 10:47 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
