Securing Elevated Deck To House - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 11:53 AM   #16
Rewards Points: 280
Ok, thanks Tom.
Have an update. Based upon the ten foot ledger span, I would have needed 7 through bolts AND at least SIXTY 12d nails. That seemed excessive and unrealistic for a 10 foot board.
I called the code inspector and there was an update. The through bolts are now at 2'8" o.c. and the 12d nails are now 3 each at 16" o.c.
Earnie is offline   Reply With Quote
Old 08-19-2011, 01:16 PM   #17
Do you need a permit for a "repair"?
UFoPilot is offline   Reply With Quote
Old 08-19-2011, 02:38 PM   #18
Rewards Points: 280
Good question. I have not asked; maybe I should.
I just suspected that since the deck was not built to current code, if it was touched structurally in any way, the re-work had to be to current code.
Curious what type craft you fly?
Old 08-25-2011, 07:46 AM   #19
Rewards Points: 280
I could use your experience on this question.
Do all building code departments use labor costs to calculate the permit fee?
This is my first time applying for a building permit. I downloaded the application and started to fill it out. One fill-in-the-blank is Total Project Cost: $ _____ .
I call the building department. I'm told the Cost is the total cost of the project which is used to calculate the permit fee. So I ask why is labor a factor. No answer other than that is what the county commissioners decided.
I can build a box and use my labor for a total cost of say $500. My neighbor can build the same box but pay someone $300 to build the $500 box. My permeit fee would be different than my neighbors for the same box.
One example of why people dislike permits.
How does it work in your area?
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Tile floor on elevated deck using GratedeX deck underlayment system. mccallaway Flooring 9 06-29-2011 10:47 PM
slope of elevated deck need ideas to make it look right johnny67 Building & Construction 7 06-09-2009 02:59 PM
Elevated Deck and Real Brick Wall stubits Carpentry 1 06-05-2009 06:14 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
