Securing 2x4 To Almost 100 Year Old Cinder Block - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 04:51 PM   #1
Rewards Points: 198
securing 2x4 to almost 100 year old cinder block
i'm installing furring strips to the cinder block so i can drywall. i'm having a hardtime getting tapcon concrete anchors to tighten as the cinder block just crumbles.
is their an easier topion?? liquid nail?
tx
vote4Pedro is offline   Reply With Quote
Old 08-07-2011, 04:54 PM   #2
Rewards Points: 6,652
Liquid nail. If you use a powder-set, what happens? You may have to use a light load to just set, but not break the block.
Old 08-07-2011, 06:47 PM   #3
Rewards Points: 5,336
tx
Put the fasteners into the mortar joints, not the block.
Ron
B. Franklin 1759
Old 08-07-2011, 09:36 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
The way I installed wood to a block wall was to use construction adhesive and to drill a hole the size if the screw through the wood and into the block, take a single strand of #12 romex electrical wire, leave the insulation on the wire. Cut the wire a little longer than the screw (Use deck screws) and insert in the hole and bend the wire over to a 90 about a 1/4 inch so the wire won't fall into the hole. With the wire in place screw the wood to the wall, the wire will make the screw bite into the block and will pull up tight and hold.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 11:48 AM
Wire through cinder block Red Squirrel Electrical 9 07-04-2010 05:45 PM
How to Repair Cinder Block Foundation Cracks Germwise Building & Construction 4 07-01-2010 12:14 PM
building concrete steps cinder block frame? drewhart Building & Construction 2 06-10-2010 02:48 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
