Old 10-03-2012, 02:45 PM   #1
Secure Post to Deck
Hello Everyone, I'm building a new screen porch / deck onto my house and my question is how do I secure the post on the deck so that they don't move? All of my post on the screen porch are attached together by a 1x4 and are flush with the band. I've been trying to figure this out for sometime, any help would be greatly appreciated thanks.
snrubr is offline   Reply With Quote
Old 10-03-2012, 03:09 PM   #2
Secure Post to Deck
I used 4x4 post and mounted inside the rim joist with 2 bolts through the rim joist and post.
Also add blockings on each side to limit lateral movement.
(*ignore the bottom wood piece under the post)
allthumbsdiy is offline   Reply With Quote
Old 10-03-2012, 03:55 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Secure Post to Deck
there should be a peice of blocking where the carriage bolts are shown.
the peice of 2x6 or 8 thats on the bottom will act as a water trap which can accelerate rot
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mae-ling (10-03-2012)
Old 10-03-2012, 06:13 PM   #4
Civil Engineer
Secure Post to Deck
If you are building a deck, you may want to check with your local building inspector what code you are under. If you are under the International Residential Code, minimum post size is 6x6 inches. Connection details are clearly shown in the IRC prescriptive deck construction guide, available typically from the building inspector or on line. But you really should start with the building inspector, unless of course you live in an area with no inspector and no code, in which case I would simply follow the 2009 IRC guidelines.
Old 10-03-2012, 07:49 PM   #5
Secure Post to Deck
yeah, i was dealing with a 10 footer by myself so i needed a pair of extra hands. that piece has since been removed.
as far as additional blocking behind the post is concerned, any tricks to deal with those bolts sticking out?
Old 10-03-2012, 07:54 PM   #6
Secure Post to Deck
Post should have been counter bored so the bolts, nut and washer do not stick out so far.
Old 10-03-2012, 08:05 PM   #7
Secure Post to Deck
Thanks Joe.
I did think about counter sinking it but was hesitant about reducing the width.
I still have access from the bottom so I will work up a solution and post back for updates.
Well, OP, you now know what *not* to do
Old 10-03-2012, 09:04 PM   #8
Secure Post to Deck
It's counter bored not counter sunk. Counter sunk would have a angled hole at the bottom.
Fastest way is using a paddle bit, a forister bit will also work.
Tags
deck, posts, secure
Replaceing 6" x 6" post on a settleing pool deck. Queequeg152 Building & Construction 7 08-21-2012 11:29 AM
Deck Post Lighting obxbnd Building & Construction 7 08-09-2012 09:44 AM
Beam to post question for a deck... dbldee20 Building & Construction 0 06-04-2012 10:24 AM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 11:16 PM
