Second Story Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 01:27 PM   #1
Lightbulb
Second story addition
I need to add on to my house to accomodate my ever growing family of five kids. I have a few questions concerning a second story addition.
As of now I have three cement pillars in my basement set 10' apart which hold up the main support beam which is four 2x8's bolted together then the floor is supported by the same 2x8's set 16" to center that are secured to the side of the main beam, not over it.
there is a load bearing wall that runs straight through the middle of the house on top of the main beam, and on top of the wall is another beam made from four 2x8's bolted togeter with the same 2x8 frame as the first floor.
Please note, the house is sixty years old and the 2x8's used are actualy 2" by 8". There are no foundation problems and the house sits straight.
My question is, could I use the existing ceiling as a floor? or would I have to rip it out and put 2x10's instead.
any answers would be greatly appreciated.
fatheroffive is offline   Reply With Quote
Old 02-12-2009, 01:38 PM   #2
This depends upon load bearing walls, size of the house, location, length of span for the 2x8's
Old 02-12-2009, 01:45 PM   #3
I live in Quebec, the house is 26'x32', the main beam runs the 32' and the 2x8's span is 14' but they reach the foundation wall at 12'.
Old 02-12-2009, 06:31 PM   #4
Contractor
cobracdn's Avatar
A good question for your local building inspector. Cheers
cobracdn is offline   Reply With Quote
Old 02-12-2009, 07:13 PM   #5
SNC
if your joist set on the wall at 12' then that is your span, 12' with a 2 foot cantalever im guessing. Depends upon the currant codes, before you tear them out, you may be able to double them up. 2x8 will cost less than 2x10, and i dont think there would be anything wrong with 4x8 16" o.c.
SNC is offline   Reply With Quote
Old 02-12-2009, 09:36 PM   #6
What is the span of the existing joists?
I doubt you will be able to use the 2x8's as a floor joist's.
Your existing foundation was most likely sized to support the load of the existing building adding onto will increase not only the dead load, but the live load as well.
Adding a second story is not as easy as one would think, you need to have a qualified structural engineer evaluate the situation.
bwalley is offline   Reply With Quote
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 06:06 PM
Half-story Addition uncleslam Remodeling 6 06-21-2008 05:17 PM
second story addition to home with a flat roof heather1115 Remodeling 1 03-30-2008 05:42 PM
Question: second story addition to existing room elmorem@gmail.com Building & Construction 3 02-17-2008 10:38 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
