Second Floor On Horizontally Cored Bricks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 05:53 PM   #1
second floor on horizontally cored bricks
I have a double brick and cavity type walls and I would like to build a second floor extension an top. The inner leaf of brickwork carries the concrete tiled roof at present. This wall is constructed from horizontally cored clay bricks. Is it possible to support the upper floor loads on this wall?
Aussie Pete is offline   Reply With Quote
Old 01-13-2009, 06:23 PM   #2
Rewards Points: 5,336
From the post, I'll make two assumptions. You're from, "down under" and you have no wood framing. I would consult a local engineer or architect for the weight bearing abilities of your construction.
Very few people who post on the internet know their rear end from their outback.
Ron
Old 01-13-2009, 07:24 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
Any time you more than double the load, I would be very suspicious of the ability of a single leaf (or wythe) of brick supporting more than twice the vertical load.
Brick are really not cored horizontally, but are rotated 90 drgrees when laying for some reason (it could be for ventining a cavity), but the load capaicty is usually reduced. You probably have some Boral brick (manufactured by Boral or an acquired country), but the manufacturing process has not changed.
You need alocal structural engineer to give you some options.
concretemasonry is online now   Reply With Quote
Problem with bricks in fireplace box pulling away from interior wall proofer Building & Construction 1 06-15-2008 07:54 AM
